'67 Intermediate Steering Shaft Removal
How does it come apart where it attaches to the steering column? There is no bell like on the later models and my book doesn't cover anything else.
There is a clamp with a big washer and a spring, which I have loosened but the shaft won't come out of the bottom of the column. Any ideas? Thanks! |
TILT COLUMN GURU
![]() Join Date: Dec 2006
Re: '67 Intermediate Steering Shaft Removal
67 & 68 shaft is one piece from gear box to steering wheel.
kevs_classics64 64 Impala SS Conv 72 Blazer 2wd 75 Jimmy 2wd 63 Belair wagon 02 Silverado ext cab. DD RIP EL JAY Last edited by KevsClassics; 08-20-2009 at 08:25 PM. |
Dang. I'm trying to do the 'shorten the steering column' thing and I can't get the collapsible part to slide together. So I guess I'll have to remove the entire column?
The shaft will not collapse since it is one piece. You will want to get a shaft and shaft extension out of a 69-72 column so removing the column is needed. (Or get the the whole column and extension).
JIm
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
