Old 01-11-2003, 07:22 PM   #1
ocbaud
Garage Queen Material
help with bumpstop removal
i got the leaf plate trimed and the shock extenders on, but now i'm having trouble getting the bump stops off!
i've grinded off all four heads that are facing toward the ground and i cant get the damn thing off!
this is the only thing holding me back
ocbaud is offline   Reply With Quote
Old 01-11-2003, 07:27 PM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
Eric,
use a hammer and punch to knock what's left of the rivet out. If you got the bottom head ground off smooth, it should pop right out.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 01-11-2003, 07:55 PM   #3
low 84
low 84's Avatar
you can also get a big crow bar and put the tip in the space that is open between the plate and the frame, and put some grunt into it and it should pop off.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-11-2003, 10:39 PM   #4
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Eric,
I had to use a 3x rivet gun to knock mine out and that's when my truck was brand new now your's is 15 + yr's old it may not be that easy but dont be afraid to beat the snot out of your truck yelling really loud cuss words as you hit it seam's to help
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-12-2003, 01:30 AM   #5
ocbaud
okay, here is the deal.
i've grinded off the bottom rivets on the bump stop so that its all flush. i can barely see the outline of where the rivets are at to hit. i've tried with a hammer and hole punch and that didnt work. i tried with a hammer and chissel, that didnt work. i've tried prying it off, but that didnt work either.
maybe tommorow i'll get something really long to pry it with and see if that works.
Old 01-12-2003, 03:14 AM   #6
low 84
low 84's Avatar
i had to get really mad at mine. they are stubborn, but it will come off.
'05 1500 Crew Cab
RIP
Old 01-12-2003, 03:23 AM   #7
78SilveradoSWB
78SilveradoSWB's Avatar
Question
Could he heat the area with a blow torch to expand the metal surrounding the rivit, then punch it through?
78SilveradoSWB is offline   Reply With Quote
Old 01-12-2003, 03:29 AM   #8
Prerunner1982
Prerunner1982's Avatar
not sure if that would also heat the rivets causing them to expand and make it harder.?
Prerunner1982 is offline   Reply With Quote
Old 01-12-2003, 03:43 AM   #9
78SilveradoSWB
Well at least the metal would be softer and more workable, I think?
