How to remove door panels
Hi all,
I did a search on this and found a vague answer. can someone be more secific on how to do this? My main problem is removing the window crank and the door pull. In the thread I saw it said to get a specific tool and it will pry and release some kind of clip? I have those hard plastic pry tools for interiors do I was wondering if i could use those. One guy said he used a butter knife. If it matters mines a 71 c-10. Thanks for your help ![]() Last edited by El_Crnicero; 08-21-2009 at 03:11 AM. |
Re: How to remove door panels
Check LMC on their door components page 18. Part #26 illistrates what you need. Bought mine at NAPA. My handle tool didn't work recently cause po mangled the clips. I bent a small nail to hook on to it. Used my pliers to hang onto the nail. Tricky and frustrating job.
The door panel tool works well. I have also used a small hook tool. You can also use a piece of a rag and let it snag the ends of the clip, then pull the rag and the clip will come with it.
Yup...I bought mine at napa too...works good
Got mine from Eastwood, I believe, but you really need the correct tool to do it right and not scratch up or mangle the door panels.
Moderator
![]() Join Date: May 2007
harbor freight sells a multi-tool door panel removal kit.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
the door handle tool is way to cheap and saves way too much hassle not to have one.
You can get them off many ways but the tool is cheap. We sell tools for that and its a quality piece of sheetmetal for $3.99 or cheaper in quantities of 5 or more
How much at the retail outlets (Advanced, Napa, PartsPlus etc)?
![]() Join Date: Dec 2008
o ring pick works good too
