08-21-2009, 11:38 AM | #1 |
POR-15 Brushers step inside please
So wanted to get feedback on people who have done their frames with POR and brushed it on. It seems to me like might be tough to get in all the nooks and crannies. How did it work for you guys?
I will have mine down to the rolling chassis and may even pull the motor but figuring out how to get everything around the front suspension and cross member with a brush is just baffling me. |
08-21-2009, 12:07 PM | #2 |
Rods
Re: POR-15 Brushers step inside please
They sell swabs but i would just spray it with a cheap gun from h.f or northern
Just keepin it simple. 1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?) 1966 C-10 lwb 283 auto 1970 Suburban in pieces 1971 Blazer 4wd....restore someday. all factory CST 1972 Blazer 4wd parts truck still a roller 1972 GMC Sierra Grandee 1998 Chevy ext driver. 2005 F**D the wife drive...(cant fix women) |
08-21-2009, 12:14 PM | #3 |
One tip make sure you USE GLOVES !!!!!
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " Last edited by slepysal; 08-21-2009 at 12:14 PM. |
08-21-2009, 12:25 PM | #4 |
Keep It Simple Stupid.. Nope..
I did my entire frame using a brush and the Matte Black POR15. I used a 2.5" brush on the main frame and a 1.25" on the suspension and all. If you spray it, it runs like crazy and with the cost of it that's alot that ends up being wasted. But the moment you stop using the brush or the paint, don't be surprised to see something harden. But definitely wear gloves and clothes that you don't mind never getting cleaned again. It's tough though, mine survived a Bobcat blade with ease.
1963 GMC SWB Fleetside in Sunburst Orange Metallic 305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire. – Custom Classic Trucks |
08-21-2009, 12:26 PM | #5 |
But if you spray it make sure to get the Solvent.
08-21-2009, 05:11 PM | #6 |
Its Deja Vu time again
Sorry for the HUGE photos, but I wanted you to be able to see the detail. Yes I used several Paint brushes. Man when the paint sets up you can not or will not be able to use an old brush. I'm almost for sure you do not want to reuse a brush either because it will contaminate the paint.
Before I started grinding: After: POR-15 is supposed to be self leveling and it appears to work pretty well. Remember the overall finish is dependant on the level of surface prep on the metal your striping. I did an OK job, but not a perfect Job. As for the little hard to reach spots I hope you have small hands. Its not as shinny as it appears in the last photo anymore. I used the Chasis black which is the top coat and its a bit flat and provides a UV layer of coverage. You can follow my work in my signature if you want. Last edited by kizer; 08-21-2009 at 05:13 PM. |
08-21-2009, 05:14 PM | #7 |
Here you go, This is what the Chasis black looks like. Its got a real nice flat look to it.
08-21-2009, 05:18 PM | #8 |
Gen III Power
Some day I would like to POR-15 my entire chassis.
Is that chassis bent in the rear ?? Those cross members are far from sighting to each other ??(Specially the center support beam ) Kinda curious unless its an illusion.
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... Last edited by hessian18; 08-21-2009 at 05:19 PM. |
08-21-2009, 05:45 PM | #9 |
You know that is odd. I watched the truck go down the road before I bought it to make sure the frame wasn't bent.
I'll have to look at it when I get home. hahaha Welp in the rusty top picture it looks squared up. Might be an odd optical illusion. I guess POR15 does more than paint it tricks the mind and camera too. Unless I'm out right bonkers which could very well be. |
08-21-2009, 05:56 PM | #10 |
Junior Member
I found the foam brushes to work the best. When I get to a nook or cranny I just squish it in there. I use the 4" foam rollers that give a finish as good as any brush on the large areas.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
08-21-2009, 06:17 PM | #11 | |
Kizer.....your frame looks nice work my wife is gonna apply the POR to our frame....and yes she has small hands
CHEVY ONLY Last edited by joe231; 08-21-2009 at 06:18 PM. |
08-21-2009, 06:49 PM | #12 |
Gen III Power
Ok well thats good news. It must be another odd thing Chevrolet did ahahh !!
Looks killer !!
---Bob--- '81 Long Box. 2005 5.3l Vortec and 2005 4L80e coming soon... Last edited by hessian18; 08-21-2009 at 06:50 PM. |
08-21-2009, 08:09 PM | #13 |
Kizer looks great!! Hope mine comes out that well.
I talked to a guy over POR today and I think we came up with a pretty good plan. I am going to top coat with a spray paint so any of the tight spots that I can't get with the brush; I will get with the spray paint. Not optimal I guess but better than nothing and it will all be a consistent color. |
08-21-2009, 08:38 PM | #14 |
100% gearhead
X2 on the foam brushes. Get some cheapies though cuz you will need a few! The finished product is nice and smooth. Also, the swmi gloss is nicer IMO. The finish lasts longer. The gloss dulls up a bit and UV rays make it milky lookin'.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
08-21-2009, 10:50 PM | #15 |
Senior Enthusiast
You might want to check out the following link for some durability observations and safety concerns about spraying POR:
http://67-72chevytrucks.com/vboard/s...&highlight=por |
08-21-2009, 11:05 PM | #16 |
I coated the whole frame, cross member and suspension w/ it. It goes down nice and a little goes a long way. However it scratches off easy. It might be becuase I got it media blasted before I applied the POR 15. I followed their instructions to the word. It might work out better if you leave the rust on, but do you really want rust under there?
08-22-2009, 10:11 PM | #17 |
Junior Member
Medial blasting first may not have helped its adhesion. It is made to Paint Over Rust
08-23-2009, 01:53 AM | #18 |
POR-15 Chassis Black. At least you can see some of it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
08-23-2009, 08:58 AM | #19 |
I used different sized foam brushes to paint the fllod truck frame, because I found that I needed to sop paint into some tight places and they work better at that and hold onto the paint with out splattering.
Way back in 2003 when I first got into restoration I use a 2 part Martin Senior epoxy, to spray the frame, What a waste of money. Had I known about Por 25 at the time I would have used that. Jake
http://s1299.photobucket.com/user/jb...23904108567829 |
08-23-2009, 09:12 AM | #20 |
Redefining LowBudget
por 15 then a few rattle cans of rustiolum satin black...I use the industrial cans it seems to hold up better takes awhie to dry but worth it and touch up is a breeze
08-23-2009, 10:06 AM | #21 | |
I did a frame about a year ago with POR15 and got side tracked on some other things and the only thing that happened to it is it faded. I am now aware that if I am going to use POR15 that I need to apply some kind of UV protection. But actually I like the way it faded and I personally like the way it looks better now. I am about to build it into a 67 ShortWide and I think I am just going to leave it the way it is. My Son was the one that painted it and he complained for a month about that stuff getting on his elbows. We laughed about it a lot and it wore off eventually. JRBECK64 |
08-23-2009, 03:42 PM | #22 |
I brushed all my POR-15 on. The self leveling thing really works!
Here's some tips I have learned from my experience with the stuff:
Greg Smith a.k.a. "The Highlander" 1966 C20 Custom Camper, 2017 Chevy Silverado 1500 Highlander's Project Pics Highlander's web site: www.6066ChevyTrucks.com Last edited by Hilandr451; 08-23-2009 at 03:44 PM. |
08-23-2009, 04:19 PM | #23 |
I agree with the mason jar I also take a piece of plastic rap and lay it over the liquid to form a air tight seal and heres another secret put it in the freezer..it won't freeze but helps alot
08-23-2009, 05:29 PM | #24 |
check out my album, i have some pics of my frame and bottom of my bed when i did it and i think it came out pretty clean.
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
08-23-2009, 05:29 PM | #25 |
Nice post Greg!!
Hottrucks, good idea about the saran wrap. what does putting it in the freezer accomplish?
CHEVY ONLY |
