Old 08-21-2009, 12:27 PM   #1
'87 Static Slam
'87 Static Slam's Avatar
DJM Control Arm Problem
when i had DJM control arms installed i could not get the alignment correct. I had to make custom upper control arm mounting bolts (2" longer). then i had to use lots of shims and welded them together after it was aligned. Has anybody had to do this? Im starting to wonder if they put the arms on the wrong side. One side of the arm is longer than the other, can anyone tell me which side is which?
Also, does it matter if the ball joint is mounted on top or bottom of the control arm?
Thanks, any help would be appreciated.
'87 Static Slam is offline   Reply With Quote
Old 08-21-2009, 12:47 PM   #2
kevinr1970
Re: DJM Control Arm Problem
I can't offer any solutions, but when I did the DJM LCA's on my '06, I could never get the alignment right.
And they weren't very helpful in trying to figure out what was wrong - "there must be something wrong with your truck". That I had since new and was putting these parts on with about 6k on it.
I will be looking else were in the future when buying suspension parts.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 08-21-2009, 01:20 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
here's what mine look like.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
