01-11-2003, 07:40 PM | #1 |
Will this steering will fit our trucks?
It came out of a astro van, i dont know if it will bolt on or not. Please let me know what it takes to make it work.
thanks John PS it might be for sale too |
01-11-2003, 07:48 PM | #2 |
Yes it will fit. how much?
01-12-2003, 02:11 AM | #3 |
its all about the +6 inches
Got one mounted in the longhorn right now.
01-12-2003, 03:20 AM | #4 |
What did you do about the horn button setup behind the steering wheel, do i have to pull the contact off of the astro to make it work or can i use the original horn button contact. I just tried to slip on steering wheel to check fit and the splines seemed to big didnt want to catch, so does that mean my splines on my steering column are a little worn down??? If i do sell how is 30 dollars plus shipping????
thanks John |
01-12-2003, 04:25 AM | #5 |
I will take it for sure for $30 if piston doesn't
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
01-12-2003, 09:24 AM | #6 |
The one on my truck is off of a astro van. I took the wire for the astro van and sanded the ears down on the part that locks in the column so it would fit tightly into the 72 contact. and took the astro contact and shoved into the 72 contact
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
01-12-2003, 10:24 AM | #7 |
PM Sent
01-12-2003, 10:27 AM | #8 |
I put one on my truck, and I love it, very easy to install
DR67
Dave Knoxville,Tn. |
01-13-2003, 11:06 AM | #9 |
I put one on about two weeks ago. Just pull the old wheel, turn the little spring loaded thing until it fits through the new wheel, and bolt it on. Make a little jumper wire aobut 3-4 inches long with a bullet connector on one end and a female spade end on the other. HOld the spring loaded thing with a pair of needle nose pliers and slide on the bullet connector. Slide the spade bit on the astro horn pad and your done.
Drives nice and looks good in my 67. I am going to paint the column semi gloss black to better match the wheel, as mine is tan currently, but it really does drive nice with the new wheel. OCB |
01-13-2003, 11:11 AM | #10 |
nice idea
What year of astrovan are you guys pulling these wheels out of? thanks in advance.
01-13-2003, 07:07 PM | #11 |
mines out of a 91
01-13-2003, 07:19 PM | #12 |
ok guys
I have it installed and it was simple all i did was took off the old horn contact and replaced it with the Astro van horn contact and bolted on simple as that thanks for the help. John |
01-14-2003, 12:14 AM | #13 |
jjg, you may have to pull it again.
I installed the horn slip ring out of the donor S-10 that my wheel came out of and it didn't work properly. The truck ring has a tapered clar on it to hold the upper bearing in place while the new ones don't. If your wheel starts flopping up and down, that's whats wrong. Just went through this last month. |
01-14-2003, 03:36 AM | #14 |
Now the others dig........
I got one too...
I used the original horn contact ring.
the ring has a 'nipple' wich when depressed returns with a little spring....what I did is I opened up a butt connector, slipped it over the little metal 'nipple' pressed it shut with some plyers and then I crimped on a 3 inch wire with a spade connector, and put on a wire with a female and male spade for the horn button. Connected them right up..no prob. Only thing is that mine has space between the turn signal housing and wheel. No biggie...nice looking wheel.
68 Chevy C10 Stepside Black Primer 78 GMC Longbed White 09 Chevy Silverado Shortbed Granite Blue LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala MEMBER OF THE DRUM BRAKE CLUB Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX Certified Music Educator I hope Mom is up there watching and being my Guardian Angel "I've got a fever.....and the only prescription.....IS MORE COW BELL" -The Legendary: Bruce Dickenson "F#$@ 'em up!!!!!!" -The Legendary: Rogelio Escobar TRUCKY LINKS http://67-72chevytrucks.com/vboard/s...d.php?t=457750 http://67-72chevytrucks.com/vboard/s...d.php?t=461184 http://67-72chevytrucks.com/vboard/s...d.php?t=472848 http://67-72chevytrucks.com/vboard/s...d.php?t=417541 http://67-72chevytrucks.com/vboard/s...d.php?t=477788 |
01-24-2003, 08:01 PM | #15 |
Thats the Hillbilly way
BB Got a new steering wheel
I want to thank SWINGSAX68.
for posting on another tread how to adapt the Horn contacts.
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
01-24-2003, 11:07 PM | #16 |
How much smaller in diameter are these wheels compared to the stock ones...??? Are they a soft-grip style...???
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
01-25-2003, 12:33 AM | #17 |
Vinnie;
They are about 14' and semi-soft grip
01-25-2003, 12:35 AM | #18 |
KEEP ON TRUCKING
i got the camaro wheel which is real close to that and i love mine
72 cheyenne 2wd lwb 71 k20 sons bassett va |
01-25-2003, 09:24 AM | #19 |
I had cut the tappered part off my old contact ring, intalled that first, then installed the ring that goes with that wheel. Works great for me!
01-26-2003, 09:26 PM | #20 |
You are very welcome Bill72BB,
The first time I've actually been of help!!! One more thing to all...be sure to wrap any live-feed parts with some electrical tape...or you might have your horn sounding nonstop!!! However I am having a problem...my wheel doesn't go in all the way to the turn signal housing....I don't know why...its not a big deal....I just think it would look a little neater if it did.
