Old 08-21-2009, 03:20 PM   #1
hittinseedz
hittinseedz's Avatar
ac not cold enough
i have a 70 c-10 and the ac blows just cold enough to keep you from sweating. the system has a full charge. where should i start first
hittinseedz is offline   Reply With Quote
Old 08-21-2009, 03:30 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: ac not cold enough
Check your heater shutoff valve. If it is not closed when the A/C is on, the heater core will get hot, and work against the A/C.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-21-2009, 03:31 PM   #3
Ryan Hubbard
Make sure that your heater valve is working and is cutting off the flow of coolant to the heater core. This will cause the air to be heated.
Ryan Hubbard is offline   Reply With Quote
Old 08-21-2009, 03:45 PM   #4
hittinseedz
the heater hoses are not hooked up
Old 08-21-2009, 04:52 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
So check to see if the door in the unit is moving all the way and sealing.Another cause could be debris in the ductwork.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 08-21-2009, 05:22 PM   #6
leddzepp
Moderator
leddzepp's Avatar
Check your cowl fresh air vent (under the hood, passenger side firewall) to make sure it is closed when the A/C is on. I will bet this is your problem. If it is open, it is allowing outside air to mix in, and thus robbing you of cold air. Also check to see that the recirc vent (in the cab on the pass side kick panel) is open when the A/C is on, or you will have a huge loss of airflow
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-21-2009, 07:10 PM   #7
68gmsee
Active Member
68gmsee's Avatar
Couple of questions: Has it worked before? And is it an original A/C truck with the old compressor?
Many years ago, I fought a similar problem on another vehicle. Finally, I got tired of messing with it and bought a new compressor and that took care of the problem.
If your compressor is old it may be that it's just not working effeciently. I'd check all of the things mentioned and then you may have to bite the bullet and go the whole way.
68gmsee is offline   Reply With Quote
Old 08-21-2009, 07:15 PM   #8
WorkinLonghorn
WorkinLonghorn's Avatar
If all of the above checks out,feel the return line going towards the compressor.It should be very cool (40-50 deg.) . If not you could have an overcharge condition or other problems,such as a stuck expansion valve,restricted screen,or maybe the "power element bulb" is loose in it's fit against the evap.outlet tube.The entire length of the of the bulb must me in tight contact or you will get poor cooling.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme.
WorkinLonghorn is offline   Reply With Quote
Old 08-21-2009, 09:32 PM   #9
BCOWANWHEELS
You might want to wash out the evaporator in the fiberglass housing under the hood. I,ve seen em real dirty this will not cool as good. Did you measure your refridgerant with a scale when charging system
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-21-2009, 10:14 PM   #10
hittinseedz
thanks for all the replies. i want be able to check everything until sunday. i will post after that.
Old 08-21-2009, 10:30 PM   #11
HuggerCST
HuggerCST's Avatar
What are your refrigerant pressures on the high and low side? Is it still R-12?
By the way, Welcome!
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 08-23-2009, 12:25 PM   #12
hittinseedz
the recirc vent is open. ac has been converted to 134, lowside has 50 psi, how can i tell if the cowl fresh air vent is closed, any pics would be appreciated, thanks
Old 08-23-2009, 12:29 PM   #13
leddzepp
Moderator
leddzepp's Avatar
Look underneath the cowl on the passenger side. The door is controlled by an actuator on the firewall (you will see the setup when you pop the hood) You might need a flashlight to see it in the cowl.
I am at work, and don't have a camera or pic, but I am sure someone else will post one if needed.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-23-2009, 12:47 PM   #14
hittinseedz
when u look at it through the cowl it appears to be flat, when i press the actuator it puts it at 45 degree angle, so with it being flat is this the closed position
Old 08-23-2009, 12:54 PM   #15
leddzepp
Moderator
leddzepp's Avatar
yes, that is correct. it needs to be closed when the A/C is on. check to make sure that is the case with the truck running, and a/c on. if that is functioning properly, you could have some dirt/debris in the evap case housing, or an expansion valve problem as described above.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-23-2009, 01:09 PM   #16
hittinseedz
ok F.a.v. is closed with ac on and truck running. what do i need to do to clean evap. also how much is a expansion valve. thanks
