08-21-2009, 05:20 PM | #1 |
How to ID a 2WD Steering Box for x-over use
So after putting a 4" lift on my K5 earlier this year, I'm getting closer to biting the bullet and doing a x-over steering setup on my D44. A fairly expensive piece of this conversion is the 2wd box at ~$200 not including a core.
I got our original family business '55 GMC delivery truck back from my cousin's x-husband over a year ago, literally in baskets, boxes and various forms of dis-assembly. I don't exactly know what the dude had planned for his restoration but he did put on a new GM PS box as seen in this picture: http://gallery.me.com/leamonland#100...&bgcolor=black I plan on returning the '55 to the original box so I won't be using this one anyway. Is it as simple as looking at the sector shaft to ID it?
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf Last edited by Oilbrnr; 08-21-2009 at 05:25 PM. |
08-21-2009, 05:58 PM | #2 |
Re: How to ID a 2WD Steering Box for x-over use
The difference is in the sector shaft.On a 4wd the pitman arm slides onto the splined shaft with a nut and bolt holding it on through the side.The shaft is keyed,like a 1/2 circle,on the side for that bolt.On a 2wd the pitman arm slides onto the splined shaft with a nut threaded onto the end of the shaft to hold the arm on.The boxes (cases) are identical in appearance.The arms are absolutely different and not at all interchangeable.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-21-2009 at 05:59 PM. |
08-21-2009, 06:37 PM | #3 |
Also the 4wd swings the pitman arm from front to back when on the vehicle, and 2wd swings from side to side.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
08-21-2009, 06:45 PM | #4 |
So a threaded sector shaft is what I should look for. Thanks.
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
08-21-2009, 07:32 PM | #5 |
Yes.There`s no mistaking it.
08-22-2009, 08:13 PM | #6 |
You can get them at the junk yard for $25. So if you have the wrong one, save some money and get one there. Just be sure the lines are the non o-ring type. Put your money into the steering arm, hardware, and machining the knuckle.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
