Old 08-21-2009, 08:14 PM   #1
mikey531
mikey531's Avatar
Am I happy or sad?
I just discovered the 350 engine in my truck has 305 heads. What is the advantage/disadvantage or reason ???
mikey531 is offline   Reply With Quote
Old 08-21-2009, 08:53 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: Am I happy or sad?
Most of the 305 heads had smaller combustion chambers. Effectively raising your compression ratio. Unfortunately most of them wont flow enough for you to ever see a performance gain. Cant imagine it hurting anything if you are just driving around.
--Josh
Old 08-21-2009, 08:55 PM   #3
mikajo39
Gearhead and audio junkie
mikajo39's Avatar
Well they don't flow very well and they're usually low compression 76cc smogger heads.Go find a pair of vortecs and GO!!!!
mikajo39 is offline   Reply With Quote
Old 08-21-2009, 09:03 PM   #4
vanceman
I agree they don't flow as well, but they are usually HIGH Compression heads. I have had them on my 350 for several years and have not had any trouble, in fact I kind of like them.
vanceman is offline   Reply With Quote
Old 08-21-2009, 09:34 PM   #5
68C15
blood type; Retumbo
68C15's Avatar
you must be happy. you have small chambers shrouding the flow in and out, small ports keeping large amounts of air at bay, high compression making you use costlier fuel, and thinner casting to shave weight.
I am extremely happy with my ultra low-buck 1992 TBI heads.
68C15 is offline   Reply With Quote
Old 08-21-2009, 09:58 PM   #6
truckdude239
truckdude239's Avatar
u sure the whole motor isn't a 305?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-21-2009, 10:01 PM   #7
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
I just tell people I have a dyslexic 350!
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 08-21-2009, 10:04 PM   #8
Richard8971
I have heard of people doing this, but usually you have to have larger valves installed. Without looking at your heads, it's difficult to know if the person who installed them put larger valves in. But usually they do this to increase compresson.
D
Sherlock Holmes
Old 08-21-2009, 10:18 PM   #9
mikajo39
mikajo39's Avatar
oops haha thinking backwards tonight
flow bad with high compression to burn cleaners or something ,tiny CC right? like 58 cc cause the pistons on most 305's are pretty far down in the hole at TDC? all i know is that they don't flow well haha
Old 08-21-2009, 10:54 PM   #10
Jim_PA
This happens a lot.
Jim_PA is offline   Reply With Quote
Old 08-22-2009, 12:05 AM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
could be worse... you could have a dodge and need a tranny
Old 08-22-2009, 12:49 AM   #12
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
305 heads should be good to about 4000 RPM, so its not that bad of thing
It does raise your compression quite a bit, like to 10 or 11:1
So you may need to run premium to keep it from detonating
Combustion chambers are 58cc & they have 184 intake / 150 exhaust valves
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
