Old 08-21-2009, 10:13 PM   #1
Deryl
Check Your Door Checks
I put new door checks on by 63 after having it painted because the old ones were rather crusty. Well about a week and a half later I had the truck sitting on a hill and the driver's side door swung open on me as I was getting out. The new door check snapped at the pin on the A pillar and now I have a nice ding where the door hit the fender. I got the checks from either LMC or Classic, but I don't remember which one. My point here is that if you have them make sure you check them for premature wear. I took both of them off and the holes in both of them are already elongated (this is after about three months.) I am in the process of replacing the flat bar part that connects to the A pillar with some flat stock steel. Just thought I would pass this along.
D's 63
Deryl is offline   Reply With Quote
Old 08-21-2009, 10:15 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Check Your Door Checks
Thanks...I'll be replacing mine soon and will fix them before they go in the truck. I also spent a day banging out the dents from PO damage...sorry to hear about the mishap.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 08-21-2009, 10:17 PM   #3
Eagar1
Good Point!
I used home made plastic coated cables controlled by a spring for my old truck, and am going to do the same thing on C20. It will be a while but if I can remember I will post pics when I do.
Eagar1 is offline   Reply With Quote
Old 08-21-2009, 10:25 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I think you will find this same quality problem with aftermarket door checks no matter where you buy them. The material is just too soft. I had two aftermarket sets do the same thing, although I discovered the weakness before the door was damaged.
I sourced original NOS door checks from EBay and they hold the door open much better and show no wear. I don't know why the aftermarket can't just make things identical to the originals. Same problem with outside door handles - I had to fit washers into the handle to keep the buttons from sticking inside the housing when depressed. The OEM handle certainly didn't do that.
Old 08-22-2009, 02:05 AM   #5
Demmit_Hemmit's 65
Demmit_Hemmit's 65's Avatar
Yep...................When I was doing my rebuild I saw some of those aftermarket door stops and wasn't too impressed by them. I just reused my old ones after giving them a good going over................nothing worse than new paint and a big ding on your cowl panel....................Hemmit
Demmit_Hemmit's 65 is offline   Reply With Quote
Old 08-22-2009, 04:10 AM   #6
TopFuel1966
TopFuel1966's Avatar
Importing cheap junk is more profitable.
TopFuel1966 is offline   Reply With Quote
Old 08-22-2009, 06:18 AM   #7
63sbssbbw
UCA63
63sbssbbw's Avatar
OUCH!
let us know how your flatbar ones hold up
T
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 08-22-2009, 06:43 AM   #8
fleetsidelarry
Senior Car Nut
fleetsidelarry's Avatar
I've had the same problem. I'm going to try the Jeep Cherokee rear door checks soon as I get to the pick-a-part. I've not seen one yet so can't vouch for the construction quality, but they can't be any worse than the aftermarket ones.
Larry
fleetsidelarry is offline   Reply With Quote
Old 08-22-2009, 10:34 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
There was a thread going in the other forum about using jeep door stops. They were for the rear doors but I lost the part #. They were also dual position stops and acually held the doors.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-22-2009, 03:18 PM   #10
fleetsidelarry
Senior Car Nut
this one?:
http://www.chevytalk.org/fusionbb/sh...rch/1/#1701677
Larry
