Old 08-21-2009, 11:21 PM   #1
Gramps69
Gramps69's Avatar
Help with temp guage?
I have a '69 GMC 1500 LWB with a 292 L6. It has less than 20k miles on the motor. My problem is that the temp guage shows it is overheating when in slow traffic or at an idle. When I check the radiator, it is not bubbling hot or overflowing. In slow traffic, if I rev the motor to about 1500 rpm, it seems to cool off. Any suggestions? Thanks for your help.
Gramps69 is offline   Reply With Quote
Old 08-22-2009, 01:37 AM   #2
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Re: Help with temp guage?
Originally Posted by Gramps69 View Post
Any suggestions?
1. Check you radiator for damage. Bent fins lessen cooling ability.
2. Change your thermostat. A sticking thermostat could raise temp.
3. Check your water pump. Wear could be causing low water flow at low idle.
4. Flush your radiator inside and out. Dirt in the cooling fins can cause trouble.
That's where I'd start, keep us posted.
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 08-22-2009, 02:40 AM   #3
jwmdnm
jwmdnm's Avatar
I agree with all previously mentioned but make one additional suggestion.
Add a water temperature gauge. Hide it if you don't want to spoil the originality of the truck but I wouldn't trust the temp lights. They don't call them "idiot lights" for nothing.
I hope this helps
'67 Chevy Stepside Shortie
350 GM crate motor with original 3-spd tranny
jwmdnm is offline   Reply With Quote
Old 08-22-2009, 08:33 PM   #4
mclairmo
Sounds like a lack of coolant flow to me. Make sure you have the correct water pump and crank pulleys. The water pump pulley should be smaller than the crank pulley to keep the coolant flow up. Also, make sure to use a high flow T-Stat. Also, make sure water pump is in good shape. Try a bottle of Water Wetter from Autozone, too. If that does not work, then maybe you have a low rpm airflow problem. Try a full factory fan shroud (not the finger guard) and make sure fan is half way in and half way out of the shroud.
mclairmo is offline   Reply With Quote
