how to body drop?
hey, i was wondering if anyone here knows how to do a body drop.
like have any pictures, tips, etc. i basically need to know everything involved. its a 78 shortbed fleet side. if that helps thanks, david Last edited by dbmx66; 08-22-2009 at 12:03 AM. |
I have car A.D.D.
Re: how to body drop?
A quick summary of the process:
Measure, plan, measure, mark your moves, measure, ATTACK!! Cut the floor loose form the rest of the body. (keeping things supported of course) Drop the body down 'X' inches. (the desired amount of drop) Build braces to re connect the body to the floor. (like was stock) Fill the gap. Make it look good, because it will be visible to most people. This is a very quick and simple "how to" but it gets you the idea. A body drop can get pretty complicated so take your time. You will have to take in to account things like the radiator support, and fender mounts need to be adjusted to match the cab. You will need to relocate your steering column, and maybe the pedals. Your seat brackets may need to be moved a bit. You may need to rewire some areas too after the drop. I hope this helps you some. Good luck! Feel free to ask me anything you want and I will do my part to try to help you anytime.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. |
#3 | |
thanks man, that seems really complicated. ive done suspension before but im new to the whole body drop thing. is that the simplest way to drop it? i was only lloking for like 1-2 inches 3 at most. thanks, david |
6.0 powered square
you could do a stock floor body drop, were you lower the body mounts on the frame and modify the mounts on cab
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
It'd be alot cooler if you did
Or just do a z and chop the bottom of the frame off (and box it of course). This would require the least amount of headaches, IMO.
that looks like a lot of work.
![]() yes it does look a bit more intense than a body lift! ![]()
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
I have car A.D.D.
There are a lot of professional shops that will not even attempt a body drop. We may be able to get this moved over to the Body & Paint board to see what the other guys' opinions are on how to do it. But, there is no "easy way".
