What is the stuff under the cross arms on the under side of the hood? Is it a sponge of some kind? Mine was rotted away and i would like to replace it but don't know with what.
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
They are called anti rattle strips you can get the from any company that sells parts for 67-72 chevy stuff they are cheep they were only 20 bucks Can. 67-72 are the same.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
What about that expanding foam,I wonder if that would work, spray it in than just trim it off
Fabricate till you "puke"
I dont think I would use expando foam, you could expand the height of the hood........
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
