Old 08-22-2009, 01:42 AM   #1
roger0080
Loose 205 Shifter Lever; How to Keep it Snug?
What is the secret to having a NP205 shifter lever work with a snug operation and not that loose-as a-goose lever action with the bolt working it's way out?
For years mine was snug and no wobbling in the lever, then one time I put it in 4WD and it became loose. I then cleaned the bolt threads, greased it all up, was good for 2-3 shifts, then blamo! loose as a goose again and I have to keep tightening up the bolt! I take this on trips out west and I don't want to loose the bolt and I don't want to keep crawling under to tighten it down.
Should I put some thread locker on the shifter bolt??
72 Chev C-10 90% restored (former AZ truck) ...
71 Chev K-20 Cheyenne my vacation crusier...
72 Chev C-10 Now retired and striped after many faithful miles...
72 GMC 1500 Retired to the junk yard after bought new in '71...
roger0080 is offline   Reply With Quote
Old 08-22-2009, 03:14 AM   #2
4x4Poet
Re: Loose 205 Shifter Lever; How to Keep it Snug?
Wave washers help.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 08-22-2009, 03:26 AM   #3
4x4Poet
Also, make sure the spring clip shafts are sized to fill the shifter rail holes. Size up, if needed, but keep their size able to be installed without tools. I've found loose fitting cotter pins there. Not good.
And use washers between the clips and shifter with a thickness to take out slop. The higher the grade SAE washers, the greater the thickness. Doubling up washers, as needed to fill the gap, is a cheaper fix. Washers also spread the force across the clips.
Too tight of a washer sandwich might transfer vibrations to the shifter in the cab. Neoprene washers on each side of the shifter's rail hole might help with the vibration issue. I haven't tried that yet.
Experiment with the small parts.
Old 08-22-2009, 07:24 AM   #4
Loc-Tite,too?
