08-22-2009, 10:46 AM | #1 |
Lowering info
What kind of info is needed to know what can drop my truck. It's a 73 custom deluxe 20 long bed
1973 custom delux 20 with 454 project 2000 dodge neon |
08-22-2009, 10:57 AM | #2 |
Blaze-Air
Re: Lowering info
Hi and welcome to the forum. I think you can find most of the info you will need in the FAQ's section. This is a question that some of the knowledgeable guys can help you with in the Suspension section. Good luck with your project.
08-22-2009, 01:54 PM | #3 |
Re: Lowering info
thanks i will check that out
08-22-2009, 03:17 PM | #4 |
Re: Lowering info
i have a 74 c-10 long bed. i cut 1 1/2 coils off the front springs and dropped the front 4 1/2" then readjusted the frontend. that took about 3 hours. then i moved the rear spring front hanger up on the frame rail 3 1/2" and added 4" longer rear shackles. to bring the rearend down. after all that i had to take out the overload plus two more springs to level it out. the whole thing cost me about $100.00 . and a weekend of work. if i was doing it over i would only cut 1 coil off the front springs. you can buy everything to do the drop and the options are endless. i went for the cheapest drop i could because i am cheap. but it all worked and looks good. have fun with it and listen to what these guys on here say most of them know what they are talking about and have experienced what you are doing to your project. everyone has their own opition . Jim
08-22-2009, 04:07 PM | #5 |
Re: Lowering info
I hear about lowering blocks. But I want to know wa I cam do to lower the front. I kno about cutting coile but I heard of cutting coils are a bad choice. I plan on lowering it put some irocs new
paint job stereo redo interior and beef up the engine. I'm am part of a forum for my car and I'm always eager onlearn sumting new
08-22-2009, 08:17 PM | #6 |
Re: Lowering info
Cutting the springs on these old trucks is ok. But make sure you measure if you cut to much the only thing to od is buy a new spring and do it again. The raising blocks dont work when they are to short.
On the back you can do a axle flip and relocate the axle cradle. No need to take springs out. Good Luck
NOS is like viagra. Impressive? Yes, but once you run out your left limp and inadequate. Racing in a Honda is like beating up a retarded kid, win or lose, you still look bad.... |
08-23-2009, 09:02 AM | #7 |
Re: Lowering info
Axle flip would lower the bak?
08-23-2009, 09:30 AM | #8 |
67-72 parts collector,…
Re: Lowering info
Are you keeping it 3/4 ton?
What kind of budget do you have? How low do you want to go? Do you plan to add drop spindles? For the rear a flip kit would get you approx.6" lower,... maybe more depending on the number of leaves in the rear leaf spring pack. You can do a maximum of a 3" drop spring up front before you run into alignment issues. You will also need drop shocks. They average about $40 each. You say your adding Irocs? Aren't they only available in 5 lug? Or did they start making them in 8-lug? We need more info. And,... WELCOME to the board!
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-23-2009 at 09:31 AM. |
08-23-2009, 01:18 PM | #9 | |
Re: Lowering info
08-23-2009, 07:01 PM | #10 |
Re: Lowering info
3/4 ton trucks have 8 lug wheels and a heavier suspension. Lowering products are not as plentiful for them as the 1/2 ton version of your truck,... which has a 5 lug wheel.
You can lower the front by changing the springs only. They come in 1", 2", and 3" drop. You can also use drop spindles that come in 2.5" or 3" drop depending on the brand you buy. You can easily lower the back 2" with a drop shackle. Any lower in the rear gets more complicated. Do you have a good selection of tools, or access to them? Please take some time to read in the suspension section. This board also has a section of "popular questions" called FAQ's. Look in the suspension section there also. Here's a link: http://67-72chevytrucks.com/vboard/s...d.php?t=262550
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 08-23-2009 at 07:02 PM. |
08-23-2009, 07:03 PM | #11 |
Re: Lowering info
Can I covert to 5 lug ?
08-23-2009, 07:43 PM | #12 |
Re: Lowering info
Yes. Early Classic Enterprises makes a "conversion spindle that allows you to use a 1/2 ton (5-lug rotor) while keeping your original style ball joints and tie rod ends. Look here:
http://www.earlyclassic.com/catalog.aspx But,... you would have to swap out the 3/4 ton rearend for a 1/2 rearend.
08-23-2009, 07:45 PM | #13 |
Re: Lowering info
By rearend do you mean bed? Or bumper
08-23-2009, 07:49 PM | #15 |
Re: Lowering info
Woah that is a lot of work. Looks like Im going to have to look for another set of rims
08-23-2009, 08:04 PM | #16 |
Dually Pride
Re: Lowering info
by rearend he meant the rear axle
best bang for your buck, i think, is 3" lowering springs, and get lowering shackles and hangers, like these http://www.lmctruck.com/icatalog/cc/full.aspx?Page=54 as for wheels, look around and you will find some nice 8 lug wheels, oh and
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
08-24-2009, 08:54 PM | #17 |
Re: Lowering info
jsut cut 1 1/2 coils off the front springs, shim the upper A arm to get the right caster for alignment. Flip the rearend wich means put it on top of the leaf springs. that way you keep the 3/4 ton springs and you can drop it. No need for spindels or anything.
Check mine out http://67-72chevytrucks.com/vboard/s...41#post3482441
08-25-2009, 02:15 AM | #18 |
Re: Lowering info
Is that what you did?
08-25-2009, 05:21 PM | #19 |
Re: Lowering info
My personal opinion is stay away from LMC. I just went through a very bad experiance with them and would not recomend them to anyone.
The best easiest way to do a good drop in summit 3in drop spings for around 80 bucks and a rear flip kit for about the same. Good cheap, easy and fast to do. I ended up doin a the 3in springs and 4 in rear drop. Took one day to do. If I could do it over I would have went with a flip kit in the rear. But now I just want to drive it.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
08-25-2009, 05:45 PM | #20 |
Re: Lowering info
When I go to summit I can't seem to find a flip kit or lowering springs for the front. Another question is if I buy for a 1/2 ton would it work for my 3/4 ton? Cus if I can find a flip kit for my truck I'll buy it and same for springs Cus I could use a drop
08-25-2009, 06:20 PM | #21 |
Re: Lowering info
the front springs are bigger on a 3/4 ton than on a half ton. also the rearend housing is also bigger than a half ton. they won't interchange. i have cut a lot of front springs with very good out come. just don't cut to much off the first time. cut 3/4 of a coil and put them back in . if it is not low enough you can cut a little more. also moving the rear spring hanger up is easy . cut the rivots and redrill the hangers and frame rails .then rebolt with grade 8 bolts. make sure to measure everything 3 or 4 times before you cut anything. the front centerline on the spring hanger has to be perfect or your truck will go down the road sideways like a dog. you can remove springs from the rear spring pack to lower the rearend more after you move the hangers. look under every lowered truck you see and ask all the questions you can before you start. i have lowered a few trucks this way with no problems. if you don't feel comfortable doing it find someone who knows how to do it right. good luck and have fun Jim
08-25-2009, 06:58 PM | #22 |
Re: Lowering info
Thats the way mine is done I will try and get close up pics of the shims and flip
08-25-2009, 09:25 PM | #23 |
Re: Lowering info
So if I do a flip kit all I have to do is put the axle on top of leaf springs. Noe do I put anything inbetween axle and leaf spring?
08-25-2009, 09:40 PM | #24 |
Re: Lowering info
The flip kit comes with a bracket for the rear axle to set it.
08-25-2009, 09:44 PM | #25 | |
Badass
Re: Lowering info
just messin with yea
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
