Old 08-22-2009, 11:52 AM   #1
bianchini
'59 apache gurus...
hey guys/ gals,
My buddy just got his '58 (put 59 in the thread title) apache restored and there are a few minor things he would like to fix.
1) on the door latches on the inside of the cab, there is a 1/2" gap between the latch and the door panel. does a grommet or something go there? i saw on his 67 work truck there was a donut looking thing. is that what is missing?
2) on the passenger side, you can move the window crank, but the window doesnt slide down. is it not grabbing the window/ window mechanism? ideas?
3) the fuel gauge doesnt work. on the '58s, is there a fuel sender that measures how much gas you have left? is it electrical? ideas?
4) what is the bolt configuration on the wheels? i see its a 6 lug...
My buddy is not the most computer savvy so I'm writing this for him. thanks for all the help and ill post up some pics tomorrow!
bianchini is offline   Reply With Quote
Old 08-22-2009, 11:58 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: '59 apache gurus...
2) You need a new regulator.
Someone else will be able to help on the other q's. Welcome to the board from down here in the south!
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-22-2009, 12:09 PM   #3
bianchini
thanks leddzepp.
also, where does everyone source parts at decent prices? members? websites? salvage yards?
Old 08-22-2009, 12:45 PM   #4
leddzepp
Moderator
leddzepp's Avatar
Here on the message board you can find a lot of parts for sale from other members. Salvage yards are hit and miss most of the time. Board vendors here have lots of good stuff. I have had good luck with the Truck Shop here in Orange, Ca.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-22-2009, 02:38 PM   #5
dwcsr
Hollister Road Co.
dwcsr's Avatar
yes there should ge a thin felt or sponge rubber donut to keep water out. You could make them from any foam rubber that is thin enough. I don't think you can buy them,
The window is attached to a sashe by a sticky rubber strip. That can be purchased and as said above it may be the regulator. You'll need to pull the door apart to see.
The fuel gauge is electric and does have a sender in the tank. It could be anything from a rotted float to the sender , wires, or the gauge itself.
wheels are 6 lug 5.5 inch pattern most GM 6 lug will fit. The only issue is that the old wheels are lug centric and the new are hub centric so the center hole may be to small on some wheels.
There are many good vendors here you can purchase from. Look in the vendor section. I would advise that you ask someone here about a particular parts supplier prior to purchasing.
dwcsr is offline   Reply With Quote
Old 08-22-2009, 07:12 PM   #6
bianchini
thanks for all the help. I screwed up the post and it is actually a '58. not a 59.
No trucks.... yet
helping my dumb friends build sweet rides.
Old 08-22-2009, 07:17 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Even better! My dad has a 58 Apache, 2nd owner, did a one-off custom restoration on it way back when. He got dogged all thru the 70's, 80's, and 90's about it.....Tri-5's were all the rage. He knew a day would come when the 58-59's would be the ticket. That day has come; I see a LOT of guys doing up 58 and 59's now.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-22-2009, 07:24 PM   #8
bianchini
yeh zepp. i took a some pics today so ill post em up in a few. he also has a 67 c10 longbed.
the hubs on the '58 are pretty big... does anyone have any rim recommendations?
No trucks.... yet
Old 08-25-2009, 05:52 PM   #9
OrrieG
OrrieG's Avatar
Nice truck. On the door handles, I think there is a thin plastic "washer" between the handle and the door panel so the inside of the handle does not scratch the paint. On the tank sending unit there is a flat metal piece that breaks so the guage quits working. I bridged mine with soldered wire a couple of times. If you turn the handle and the regulator does not move the inside is shot, usually wears a hole in the metal housing. They are reproduced now so its not a big deal. I assume the window track was bolted back to the regulator. Patrick
OrrieG is offline   Reply With Quote
Old 08-25-2009, 06:34 PM   #10
bianchini
hey Patrick,
thanks for all the help. ill try to tackle some of these issues tomorrow.
-Pete
No trucks.... yet
Old 08-25-2009, 11:33 PM   #11
OrrieG
OrrieG's Avatar
I checked the factory assy manual and the door and window handles have a plastic "washer" between the door and metal. My memory was right the inside diameter is the same as the splined shafts, the outside matches the handles. The door opener handle has a felt pad shaped like a donut between the door panel and operator bolted to the inner door panel. The window regulator only has the plastic washer. They were all missing when I took my door apart so I now have to find some too.
Old 08-26-2009, 09:05 PM   #12
Number 9
thanks leddzepp.
Try craigslist sfo parts for sale type in 1958 and you will see an ad for 1947
and up chevy parts for cars and trucks. He is in Santa Clara and has or can get
any thing you may need. That is a nice looking truck. I have a 59 big window
which is the same as your 58.
Number 9 is offline   Reply With Quote
