Old 08-22-2009, 12:12 PM   #1
grayharville
^^who I am^^ what I say>
grayharville's Avatar
headlight/windsheild wiper knob removal????
hey yall, im tryin to pull the guage bezel out of my 70, but i cant figure out how to get the headlight and wiper knobs removed so i can pull the panel out. what is the proper way to remove the bezel? thanks alot!!!!!!
grayharville is offline   Reply With Quote
Old 08-22-2009, 12:25 PM   #2
Sinister
Between Trucks...
Sinister's Avatar
Re: headlight/windsheild wiper knob removal????
Disconnect the battery, pull the knob for the lights out to the on position, reach up behind the dash, there is a small button on top of the light switch, push down on it and pull the knob out. Wiper knob has a set screw. Chrome bezels unscrew.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 08-22-2009, 12:26 PM   #3
69nova
For the headlight knob you have to reach under and behind the dash to where the wires go into the light switch and it has a button on the top. Pull the knob out then press the release button on the top and the knob should come the rest of the way out. The wiper knob should have a set screw in the actual knob that is real small. It may be an allen head but turn the knob and look for it. Side note, the head lights will stay on until you push the knob back in if you have the batt connected but hopefully you will not stick your hand behind the dash with power on.
69nova is offline   Reply With Quote
Old 08-22-2009, 01:18 PM   #4
grayharville
thanks alot! im tryin to get my dome light, and enterior light workin. the wires were chewed, and after testing, on one set of white/orange wires, the orange is makin twelve volts no matter the switch position, then the other set is the same way, except its the white one makin twelve volts. the switch does nothing. any ideas???
Old 08-22-2009, 01:34 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
Here's some links to some wiring diagrams, click on the title bars to get to them, links are being weird. Sorry I can't be of more help.
Beat it to fit,
