Old 08-22-2009, 02:01 PM   #1
Contagious209
best way to drop
what is the best way to lower my truck all around, i heard about blocks and shackles but where can i find spindles for the fronts?
1973 custom delux 20 with 454 project
2000 dodge neon
Contagious209 is offline   Reply With Quote
Old 08-28-2009, 08:51 AM   #2
tater71c
Re: best way to drop
the way I lowered my 71 was by lowering springs and drop spindles in the front the springs were 2 inch and the spindle was 2.5 inch drop then in the rear I used 5inch lowering springs and needed to use c-notches to keep the rearend from hitting the frame. I got most of the stuff from either lmc truck or cpp.
tater71c is offline   Reply With Quote
Old 08-28-2009, 10:47 AM   #3
bigbadjohn84
the 73 in your sig? Id say DJM drop spindles. how low are you wanting to go? in all honesty, I never notice much of a rear drop when shackles alone are used. now shackles and hangers do pretty well. a flip kit is an option, but then you need springs in the front unless you want to cut a little out of the front coils, and by this, I mean doing it properly if you want to maintain your ride. IE use a portaband, or cut off wheel, and even then I stick the entire spring in a bucket of water as I was cutting to keep from heating the spring too much. aftermarket springs are readily availiable and even complete static drop kits including shocks. which is a need when dropping these things. all depends on how much you want to spend and how low you want to go man
bigbadjohn84 is offline   Reply With Quote
