Old 08-22-2009, 08:17 PM   #1
rex01atv
Anybody using 20'' wheels on bagged c10 with stock rear fenders???
Please post up your bagged c10 with stock rear fenders??? I would like to see how low my truck will be before I have to modify rear inside fenders. Thanks!
rex01atv is offline   Reply With Quote
Old 08-22-2009, 08:33 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Anybody using 20'' wheels on bagged c10 with stock rear fenders???
20"X10" w/ 5.5" BS I believe with stock rear tubs, bolt in C-notch and ART rear air ride setup (danny ewing's truck if you want to search for more details) He did say it touches both the front and inner fenders as is. There is a mod (look up frizzle fry mod) for the front fenders that gets you an extra inch or so in the front.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 08-22-2009, 09:49 PM   #3
duceducenine
duceducenine's Avatar
heres mine 255 35 20 tires...sold truck though sure do miss it!
duceducenine is offline   Reply With Quote
Old 08-22-2009, 11:00 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
What gen are you looking for, 67-72 or 73-87?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-22-2009, 11:31 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
I looked at his posts and he has a 72 so that's what I assumed...but who knows...
Here's his truck with 18's
Don't think that truck's going any lower with the stock fenders...
Old 08-23-2009, 11:30 AM   #6
rex01atv
Thanks for the reply, anybody have a truck bagged that has a bridge notch using stock wheel tubs in rear?? DueceDuece did you have a bridge notch and trailing arms in that pic of your blue c10????
Old 08-23-2009, 11:43 AM   #7
rex01atv
DeuceDeuce was your truck using a bridge notch in the rear and trailing arms??? If so was your truck bottomed out on rear tubs in the pic above??
Old 08-23-2009, 12:54 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
After reading posts by many with c-notches and 20's....going to a step notch with the stock wheel tubs won't get you nmuch/any lower. With the 20's and c-notch you're going to be almost/will be resting on the tubs already. It depends on the overall height of the tire though. You might get a little bit lower if you do that but I believe you would have to modify the inner part of the bedside to fit the wheel up higher.
Old 08-23-2009, 01:12 PM   #9
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
if your bagged up front and have the cups cut out then you can go to a 29 1/2" tall tire before it hits the inner fender reguardless of rim size my front X memeber is about 1.5" off the ground dumped
if you have a 2.5" c notch you can run up to a 31" tall tire before it rubs
my set up is a 235 X 15 (29.5") up front and the front tires are about 1/4" from the inner fender with no wheel wells
my rears a 31x10.5 x 15 on the rear and they rub (they are pretty worn if they where new they woud really rub) not bad but I have about 3/8" before the axle is on the notch because it' sitting on the shocks
thats the info hope it helps
Hottrucks is offline   Reply With Quote
Old 08-23-2009, 01:44 PM   #10
duceducenine
stock trailing arms 2" drop blocks
no rubbing. sitting on bolt in c-notch
6" square cut out for pumpkin....
there is more room but youd need
a bigger notch meaning cutting the
floor out! on smoothies 255 35 20
Old 08-23-2009, 05:50 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
This is as low as you can get and not cut the bed. It has modified inner fender liners (rear) to get a bit extra, but the floor of the bed is intact and the inner wheel well is too.
Anything lower than this will require you to cut the bed, brace, fender wells, etc.
Articles-
"Refining Sierra"
Old 08-23-2009, 08:01 PM   #12
Stitch
Location: Where I come from, it's cornbread and chicken...
that looks sick...
Stitch is offline   Reply With Quote
Old 08-23-2009, 09:09 PM   #13
kev2809
low n' slo
kev2809's Avatar
thats a clean truck, is that urs n2trux?
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
Old 08-24-2009, 12:00 AM   #14
N2TRUX
Happy to be here
N2TRUX's Avatar
No, that is Lucy. She was built and owned by n2billet. He sold it and it has changed hands a few times now.
Articles-
"Refining Sierra"
Old 08-29-2009, 01:08 PM   #15
rex01atv
Okay, I shoul have said I have recently installed a kp bridge notch and have cut out the bed for clearance, I have also installes PB trailing arm crossmember with CPP round trailing arms. I'm looking for somebody that has maybe moved there OEM wheel tubs up for 20'' wheels, for which this is what i/m may do. I want to keep it stock looking as much as possible. Sorry I have no pics up yet,but soon.
Old 08-29-2009, 01:28 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Yeah, that's a small detail you left out
Old 08-30-2009, 01:04 AM   #17
gottwake
gottwake's Avatar
22s
Blazer Project
gottwake is offline   Reply With Quote
Old 08-31-2009, 04:07 PM   #18
bruce bruce
Is there a "magical" 20x8.5 and 20x10 ofset combo for this stock fender set-up?
bruce bruce is offline   Reply With Quote
Old 03-30-2014, 10:07 PM   #19
brad butt
Im running 20/8.5 with 255/40 and 295/40..just ordered boyd rogue wheels so ill be running a 10" rim on the rear.ride tech suspension stock front and rear wheel wells.
brad butt is offline   Reply With Quote
