![]() Join Date: Sep 2005
anyone ever built a trailor out of
the back end of one of our trucks? i ahd a friend give me an idea for a matching tailior for my truck was was wondering how yall did yours?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
![]() Join Date: Mar 2003
Re: anyone ever built a tailior out of
Hmmmmmmmmmmm,
couple more, sorry for the blurry
Ex-Minitrucker
The E-Brake is frickin sweet. Good job very inventive.
It makes for one big, heavy trailer.
I would just get an aluminum trailer - much easier to move around, and it will tilt. |
Yeah, but you can't put 2 1/2 yards of dirt or 4200#s of scrap metal in one of those aluminum ones
SSN 706
And the price is right.
I have built several trailers out of these trucks. They work great. One thing I do is I put a Caddy rear axle out of a mid 70's El Dorado and set the axle on top of the leafs which lowers the trailer about 5 inches. The axle tube is the same diameter as the trucks so I just weld on the spring mounts and use the truck u bolts. My personal trailer even has a hydraulic dump!
![]() Join Date: Apr 2005
Here's a shot of my 50th Anniversary trailer....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
Phone's ringin Dude.
![]() Join Date: Mar 2007
When I moved my wife out here the the 'real' midwest (she's from Ohio) she was shocked to see a trailer made out of a truck. Just a normal site that I grew up with, but she makes fun of it everytime she sees one.
![]() ![]() 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
#13 |
sweet i thinking about making one to match my truck when i am done
#14 | |
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#15 |
#16 |
BlahBlahBlah
#17 |
it wont hurt it as long as the yoke is not on the rearend it will just spin
#18 |
My Carbon Footprint
I wouldn't do it to a long bed but I would a really nice short bed!!!
#19 |
![]() Join Date: Oct 2006
If you take the yoke off the pinion will slide into the housing and lock the whole thing up. You dont have to do anything special to the rear end. We have 4 truck bed trailers that we use for firewood. They work great and are easy to build.
IF A FELLA DOESN'T USE HIS HEAD....... HE MIGHT AS WELL HAVE TWO BUTTS ![]() 1969 C10 LWB "Granpaps Truck" (Project) 2000 K3500 Crew Cab LWB (Farm Truck) 2007 Chevy 1500 Crew Cab 5.3 (Daily Driver) |
#20 |
Re: anyone ever built a trailor out of
someday I'm gonna get a suburban, and thought it would be cool to have a matching bed trailer to make home depot runs easier
#21 |
I ment the drive shaft the yoke will just spin and not hurt anything
#22 |
That is correct. The el dorado is a straight axle. It is a disposable part on a caddy that usually gets crushed. Also, I don't like to waste a good eaton axle on a trailer. Sometimes on a dana 60, I will simply cut the axle shafts off and bolt the axle plate back on to keep the ring and pinion from turning. That gives you a full floating straight axle that will handle those 4200 pound scrap loads.
#23 |
I have a 1950 short bed pick up box trailer to pull behind my 50 3100. I even have 1950 Idaho licence plates on both truck and trailer aswell. Some day I will make them look the same.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made Last edited by sweet70beast; 08-23-2009 at 06:36 PM. |
#24 |
![]() Join Date: Nov 2007
Miine is not as nice as HartRod's but it has taken alot of abuse !
72 C20 Longbed 05 1500 Z71 Last edited by sleepertruck72; 08-23-2009 at 07:54 PM. |
#25 |
![]() Join Date: Dec 2008
we always used them for firewood, cut wood in the pasture and then leave it in the trailer by the house, saves alot of uloading/loading, my buddy has two burn barrels in one, pulls it up to the house, then out back to burn when they are full.
1969 Short Stepside 1969 4 WD Suburban 1970 1 Ton Dually....Misfit oh, and a 2001 HD 2500, 8.1 Allison Shortbed 4 Door |
