Old 05-20-2002, 07:38 PM   #1
Zkast
Zkast's Avatar
Post Newer tilt column install?
Has anyone ever installed a '81 or newer tilt column? I like the idea of having a locking steering wheel/gearshift lever. I know, I know.. GM columns are not exactly safe but there is virtually nothing that keeps a person from getting into our trucks as is. Plus I would like to install the GM cruise control, intermittant wipers into my truck at the same time.
How much work is involved in cutting one in? (excluding wiring)
Pictures and more...
piston@zkast.com
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Webmaster/Team owner
www.zkast.com
Garrett - Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-20-2002, 11:30 PM   #2
Zkast
Zkast's Avatar
Post
Anyone know if this is possible?
piston@zkast.com
'71 LWB
350/350T, PS/PB
www.zkast.com
Old 05-20-2002, 11:39 PM   #3
shadetree
shadetree's Avatar
Post
It is possible, but a few things need to be fabbed, along the way. The newer column outer sleeve will need to be cut on an angle, to properly meet the 67-72 dash. Also, the windshield wiper motor will have to be swapped, as the newer controls won't work on the older motor. The locking column feature: I don;'t know if it can be made to work, as I completely disabled that bad boy, in my swap (I cringe at the thought of the column possibly locking up accidently, at speed!). This swap is "do-able", but an earlier column (73 to 78 or so) is much easier. steve
72 long fleet, 355 4 speed, primer, walnut goodies. Check out my web site: http://shadetree72.homestead.com
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 05-20-2002, 11:45 PM   #4
Zkast
Zkast's Avatar
Post
did the length of the entire assembly work out ok? and How did you mount it to the cab? floor and dash
Thanks for the input
piston@zkast.com
'71 LWB
350/350T, PS/PB
www.zkast.com
