Old 08-23-2009, 01:07 PM   #1
Boise69
The Hammer Man
Boise69's Avatar
How to identify my rear axle and gears?
I believe i have an aftermarket rear axle and diff but how to know what it is exactly is my question.
It has several casting markings around the outside of the chrome 12 bolt cover, if i post these numbers would you be able to tell?
I want to switch to 5 bolt (its 6) so i can purchase the wheels i like but i want to keep the same gearing and if i sell this set up i'd like to know what i'm selling. After reading many posts i dont believe it can simply swap the axles but i'm not sure
Boise69. Bought in Boise ID and its a '69
___________________________________________
1969 Chevy C-10 SWB 350/400 - drivable project
www.americanhammer.com
2013 MBZ Sprinter customized
2005 MBZ Sprinter Van
2004 Land Rover Discovery
2001 Yamaha Road Star
1997 MBZ E420
1989 Ferrari Mondial T
Boise69 is offline   Reply With Quote
Old 08-23-2009, 01:33 PM   #2
BarryB
BarryB's Avatar
Re: How to identify my rear axle and gears?
It's better if you can post up some pics. of the differential. If it has an aftermarket carrier or ring and pinion then most likely the numbers on the outside aren't going to tell you much. What you'll need to do is pull the rear cover off, and check for the stamped numbers on the ring gear. you can also see what type of carrier you have also. After ding so take some pics and post them up so we can look at what you have, and tell you for sure.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 08-23-2009, 01:36 PM   #3
BarryB
BarryB's Avatar
P.S. if all your wanting to do is swap to 5 lug. take your existing axles out, take them to a reputable machine shop, have them re drill for 5 lugs, and reinstall. You can either get the drums from a 5 lug or have them drilled as well, because IIRC the brake components are the same from 6 to 5 lug.
Two rules in life.
Old 08-24-2009, 08:45 AM   #4
Boise69
The Hammer Man
Boise69's Avatar
now thats a great idea, i didnt know this could be done. If i can find a shop in town i'll definately take this route. I'll take a look at the drums and determine if new ones are in order. thank you!
1997 MBZ E420
