Grandpa in the rustmobile...
how do i get the ignition tumbler out??!!!??!
HOW DO I GET THE IGNITION TUMBLER OUT OF MY 68C10?
I spun the bezel left 10000000 times and still nothing..its just loose now..what am i doing wrong or missing thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Next project: 1970 K10
Re: how do i get the ignition tumbler out??!!!??!
Tighten it back up if you can. There should be a small hole next to the key slot. Put the key in, and insert a paper clip in that little hole. Turn the key (can't remember which way, try both) and it should turn then pull out.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
crap!
old dad thought it turned out like a nut... so THATS what that lil hole is for..hmm THANKS!!!!!! ![]() ![]() ![]()
One the tumbler is out, the bezel will spin right off then.
Well i got it out and back in took awhile
BUT I CAN STILL START MY TRUCK WITH A SCREWDRIVER ANY OTHER KEY ETC WTF IM MAD LOL I BOUGHT 23$ KIT THAT DIDNT FIX M PROBLEM??!! what'd i do wrong?
sharp as a marble
![]() Join Date: Jan 2007
once you get the bezel tight, put key in, paper clip in hand, turn key to accessory put the paper clip, and turn it a bit more to the left, while pulling out on the lock cyl
ok i can pull the key out while drivin down the road etc and i can still start it with a screwdriver etc..why is this? this is the whole reason i replaced this so my mexican buddy doesnt move my truck while im in school!! lol
same thing with my truck, it is handy though after you start your truck but then have to run back inside for something cause you dont have to turn it off to get your house key! ill be watching to see if anyone has a solution, ive been meaning to do something about this before my truck gets stolen!
1970 GMC- 454 DONT GIVE ME NO JIBBA JABBA!!! |
its all about the +6 inches
what part did you replace? The ignition, or the tumbler?
(it has a worn tumbler) |
the thing were the key goes in...i think the tumbler.....if you force it you can still start it with another key (my old one)
Yeah mine does the same thing idk why, maybe someone here might have an answer.
Mitch 22yrs. Young 1970 GMC Short-Step 350/TH350 Combo. . ![]() Current Project 68 Gmc "Second Chance" Go to my 68 GMC Shorty Rebuild Thread http://67-72chevytrucks.com/vboard/s...39#post6341739 |
#13 |
Moderator
![]() Join Date: Jun 2008
inquiring minds want to know...
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
#14 |
![]() Join Date: Jun 2009
#15 |
that is a good question, in my 72 i have the sameproblem. the door key you have to use the real key, but the iginitions anythin works as long as it fits in the hole. any ideas? inquiring minds wnat to know!
#16 |
Well, if 'anything' will fit in the hole and turn it, then that's what you would use to get it out. If you don't have a key and nothing else will turn it, then I don't know. PM LocDoc, he'd probably know.
#17 |
my short fleet had the same anything will start it prob, i would for get to get my keys out of my pocket so i would just use my knife.
now im on the other end of the problem, i bought a truck and the guy lost the key, i told him dont worry they will usualy roll over with another key or knife. no dice, the thing is tight as a drum :laughing: |
#18 |
Location: Sunny, Florida, some might call it South Alabama
I ordered a new ignition and tumbler from ECE and my truck will only start with that key
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
#19 |
low n' slo
![]() Join Date: Mar 2009
good luck 2 tons of fun, i thought the same thing when i bought my suburban, and i had hell getting everything out without the key. ended up stripping my little ign. bezel and bent the hole in the dash a little...nothing i cant fix but it still was a pita
67 1/2 ton Suburban - Project DRGNWGN. Build thread ![]() -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
#20 |
I bought a new cylinder and keys from Napa,it was $23 dollars,solved the problem.
#21 |
![]() Join Date: Jul 2007
Usually you can find an old worn GM key that will turn the tumbler on these trucks. I never throw an old key away as it has saved my bacon more than once over the years.
I think LocDoc said in another thread that the passenger door key should be the same as the original ignition key if the tumble hasn't been replaced. In that case you can pull the lock out of the passenger door and take it to a locksmith and have new keys made. |
#22 |
if that doesn't work, then it is time to get the hammer and a big pinch out.
#23 |
The Older Generation
As far as getting the ignition tumbler out read this post... http://67-72chevytrucks.com/vboard/s...d.php?t=358919 If your new lock cylinder is made overseas it may not have any tumblers in it. Thats why anything will turn it. On the original lock cylinders it would either be that the tumblers are stuck, bent, worn out, or someone may have removed them. The tumblers are what keeps the lock cylinder from turning unless the key is inserted. LockDoc
#24 |
Just Not Low Enough!
i just replaced the whole thing, that solved all my issues....
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd ![]() Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
#25 |
72 GMC
I bought the matching door locks and ignition from GMC Paul's.
One key works all. I'm happy with it. |
