Old 08-23-2009, 06:54 PM   #1
MOJO1963GMC
MOJO1963GMC's Avatar
1963 GMC power steering conversion
Steer me in the right direction for a conversion. Want to get a IDIDIT column in chrome or polished alum..then top it off with a new steering wheel...I have a power steering box ,pump and brackets off of about a '78 Chevy 1/2 ton .
MOJO1963GMC is offline   Reply With Quote
Old 08-24-2009, 12:07 AM   #2
Captainfab
60-66 Nut
Re: 1963 GMC power steering conversion
I have the steering box adapter plates (link in my sig). What engine is in your truck?
Old 08-24-2009, 09:22 AM   #3
MOJO1963GMC
350 SBC...Guess I shoulda mentioned that right off the bat.
Old 09-17-2009, 07:11 PM   #4
MOJO1963GMC
Can't decide whether I should order polished alum or chrome. Chrome is cheaper but would polished alum be better?
Old 09-17-2009, 07:38 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
It's really a personal preference, and a lot depends on what type steering wheel you pick and what the other interior appointments are made of (knobs, handles, etc). To some it's very important they match. Chrome, aluminum and stainless steel are all different colors. Most people wouldn't notice the difference, but if it matters it's something to consider.
My first pick is stainless steel. It goes all the way through, so if you get a nick or scratch you can usually polish it out. 2nd choice would be chrome, since an occasional wax job will keep it looking like new, unless it gets scratched. With aluminum components, depending on how tight the aluminum material itself is, it may require occassional or constant polishing. Brushed aluminum offers it's own challenges to keep looking nice, but if that is the look you're after, it's worth the effort.
I happen to have a skin type that discolors aluminum easily so I avoid aluminum knobs as they turn dull and dark very quickly. My son has no such trouble. Just something to consider when you're figuring how much you enjoy polishing.
Old 02-04-2010, 02:24 PM   #6
MOJO1963GMC
That box out of the '78 chevy p/u will work right?
Old 02-04-2010, 02:36 PM   #7
62gmc910
62gmc910's Avatar
With 'fabs plate, try to match the power steering pump to box (metric or SAE)Sorry you mentioned that
I also think you need to use the '78 idler mount for correct spacing ??
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 02-05-2010, 01:50 AM   #8
Captainfab
60-66 Nut
Yes that box will work. All the truck based power steering boxes from '69-'87 are the same housing. The one difference to look out for is the different hose fitting type as mentioned by 62gmc910. The metric style hose fittings started in about 1981. This is true for the pumps as well.
