08-23-2009, 10:13 PM | #1 |
If this rides a rocking don't comma knockin?
Well, that's at least what my ride is sounding like right now...like there's some squeeky coils in the hand me down bed...if you get my drift. So, I was first thinking the squeeking sound...which in all honesty is louder then just a squeek was from my shocks. As I'm sure they're pretty old. I went to the part store and without looking at my truck the salesperson suggested it might also be my ball joints needed greased.
So, if it's my shocks...I am pretty sure I can change those on my own...as for the ball joints needing greased..I'm not sure what I would need to do. Are there any guides or tips? I looked in the FAQs and only found tips on removing the A arm and Ball joint. |
08-23-2009, 10:46 PM | #2 |
Re: If this rides a rocking don't comma knockin?
Some ball joints have a grease zerk on them. Just put the grease gun on and give a couple squirts. Not too much though. While you are under there see if your U-jionts have grease zerks too. There is a whole slew of front end parts that are greaseable. Someone smarter than me will chime in soon.
As far as the squeak, can you have someone bounce the truck while you walk around it and listen?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
08-23-2009, 10:59 PM | #3 |
Ok, i'm a novice so what is exactly a "zerk" if it's that easy then yes I'll go load up on grease and get a gun and do that tomorrow. I did also have somone rock the truck back and forth and it did sound like it was coming from in side the front left wheel well, but I couldn't narrow it down anymore then that.
08-23-2009, 11:42 PM | #4 |
Location: Where I come from, it's cornbread and chicken...
if you get your oil changed at an oil change grease monkey place, they should grease the chassis and suspension while their down there...you could ask/tell them to do it to make sure...
Chuck. |
08-23-2009, 11:51 PM | #5 | |
Size Matters
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News. ...WOOOO HOOOO!!!! |
08-23-2009, 11:55 PM | #6 |
Happy to be here
Pics are sooo much better for explainations. Look at the fitting on the bottom.
08-23-2009, 11:58 PM | #7 |
08-24-2009, 12:02 AM | #8 |
Happy to be here
That is correct. You should have several of the located on your front suspension "pivot" points. Pump, ooze, and wipe. Pretty simple process.
08-24-2009, 12:07 AM | #9 |
08-24-2009, 08:17 AM | #10 |
Happy to be here
08-24-2009, 10:25 AM | #11 |
Never Ending Projects
Just so you know you got them all, there should be 19 fittings that need to be greased on the front end.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
08-24-2009, 03:47 PM | #12 |
08-24-2009, 03:49 PM | #13 | |
08-24-2009, 03:59 PM | #14 |
08-24-2009, 04:23 PM | #15 |
I had a random tingy metal/pop noise come from the front passenger side suspension area this weekend. If you really push on the front passenger side fender/core support, you can make the noise repeat again and again. Damn this truck gets me frustrated!
I will also try to grease everything down...I hope it helps. Let me know if the grease helps you out. David Last edited by djw32; 08-24-2009 at 04:25 PM. |
08-24-2009, 07:20 PM | #16 |
The sway bar and body mounts can squeak too...
08-24-2009, 11:14 PM | #17 |
Think greasing it down solved part of my problem. There's now only a creak when the truck moves side to side.....but that could be from just about anything I'm assuming...but the main problem seems to have gotten fixed..I wasn't able to get to all the zerks because the first grease gun I bought was broke and it had the flexible rubber hose, and the new one didn't.
08-25-2009, 11:07 PM | #18 |
Sadness....my truck is back to squeeking. Either I didn't fill it up with enough grease, or it's leaking out or that's just not the problem. But it sounded fine last night and this morning, but driving it home from work it was back to being annoying.
08-26-2009, 10:53 AM | #19 | |
Upper and lower A-arm cross shafts (4 x 2) Inner and outer tie rods (2 x 2) Idler arm (2) Pitman arm (1) 2x2+4x2+2x2+2+1=19
08-26-2009, 12:35 PM | #20 |
08-26-2009, 12:37 PM | #21 |
This sucks. What do you think it could be? When do you hear the noise? Is it on take off, driving at speed, or stopping at a light?
08-26-2009, 11:58 PM | #22 |
Yeah, I don't know. I got under there again and re greased the zerks and my best guess is it's a shock that's just had it. So, trial and error.
08-27-2009, 12:32 PM | #23 |
Are you sure the squeaking is coming from the front? Check your rear springs and see if the plastic isolators between the spring leafs have worn away. When they wear through or go missing you can get squeaky spring syndrome.
If you need new ones, don't buy them online for $5.99 a piece! Go to a spring shop, they are only like $0.50 each! |
