Old 08-24-2009, 12:14 AM   #1
johnboymx
johnboymx
johnboymx's Avatar
4x4 to 2x4 conversion question
Will a 1978 Blazer 2wd front crossmember and suspension work in a 72 4wd to 2wd conversion?
johnboymx is offline   Reply With Quote
Old 08-24-2009, 08:35 PM   #2
layingC10nK5
Re: 4x4 to 2x4 conversion question
i think it should be the same, i used one from a 74 pick up in a 71 blazer. u will need the correct spindles. if u get it rotor 2 rotor u will have no problems but if u are planning on drop spindles ( im sure u are) u will need the ones for the year of the donor parts.
layingC10nK5 is offline   Reply With Quote
