Old 08-24-2009, 01:54 AM   #1
vegaschevy
4/6 drop whos kit?
What kits is everyone running? I see a lot of people piecing kits from various companies together.
Anyone running one companies stuff?
I want to get 4/6 drop springs and spindles, shocks, shock relocation brackets, C notch, rear track bar, and anything else anyone recommends.
This is on a 72 truck so it already has disc brakes
vegaschevy is offline   Reply With Quote
Old 08-24-2009, 03:38 AM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: 4/6 drop whos kit?
I am running mostly McGauphys stuff. Every thing except for my 2 inch rear blocks and my C notch and track bar. That all came from CPP. I am 5/7 though
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 08-24-2009, 04:24 AM   #3
BCOWANWHEELS
me too
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-24-2009, 07:51 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Use ECE. (Early Classic Enterprises)
They can fix you up with a complete kit.
The only thing they don't sell is the bolt-in c-notch. That's not required with a 6" rear drop anyway.
Keith
Convert to disc brakes.
Old 08-24-2009, 08:29 AM   #5
lks dcvn
lks dcvn's Avatar
- most of the stuff for my 2wd Blazer is from ECE - the only thing that might not be is the front stock height springs - but not sure if I will buy those yet - I might need them...
ECE 4" rear drop spings
ECE KYB drop shocks
ECE Rear Shock Relocators
ECE 2.5" front drop spindles
ECE Adjustable Panhard Bar
lks dcvn is offline   Reply With Quote
Old 08-24-2009, 08:35 AM   #6
big_al_71
big_al_71's Avatar
I used the complete 4/6 kit from Early Classics.....Perfect fit on everything....
My front sway bar is from Classic Perform Products CPP...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-24-2009, 08:30 PM   #7
jbristo67
jbristo67's Avatar
I dont know how. Granted I am at 7 inches but I would be almost sitting on my frame without it.I mean less than an inch I really would not like my rear end slamming into my frame all the time. Plus I know ECE has a great rep for customer service but I am a numbers guy. I wouldnt spend 5 dollars more as long as the quality was the same.
2011 Nissan Armada
Old 08-24-2009, 09:30 PM   #8
sourkraut
sourkraut's Avatar
I agree, you might pay a little more but the customer service is bar none!!! I had gotten 5" springs for the rear and did not like the stance and they set me a set of 6" springs and took the 5" back, just had to pay shipping! Cant say enough about ECE!!!
"The way it is" truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=359200
sourkraut is offline   Reply With Quote
Old 08-24-2009, 09:38 PM   #9
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I just measured mine earlier today, and I'm 2.5" (roughly) from the axle tube to the frame, and roughly 4" (probably more like 3.75") from the top of the pumpkin to the bed floor.
While I am with you on attempting to spend money wisely, for the fact that I didn't have to question if I was missing pieces when they arrived; I was notified that one box would be late due to not having the pieces in at that moment (when the others shipped) and knowing that I could talk with someone about any issue I had, without second guessing their opinion.... my money went to ECE.
Just my $.03... but with everyones rants/raves with CPP, I didn't want to chance the install being hung up.
Enough said... ECE all the way!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-24-2009, 10:07 AM   #10
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Another recommendation for Early Classics. Top notch products and top notch guys who know their stuff.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-24-2009, 10:31 AM   #11
vegaschevy
Has anyone rode in a truck or a few different lowered truck with different companies suspension? was there a difference? Just wondering who might have the best spring rates.
Old 08-24-2009, 10:39 AM   #12
smoky02
Location: Sunny, Florida, some might call it South Alabama
I've only ridden in my own, and I used the ECE kit. But make sure that you leave your factory bump stops in on the back, the frame will bottom out otherwise.
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 08-24-2009, 11:17 AM   #13
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
My 2.5/4.0 drop is ECE. Add an inch to the front with their lowering springs. Out back, going 5-inches or more may mean that you should consider their crossmember, which relocates the mount for the rear trailing arms as well as provides holes for the exhaust system to be routed. A track bar is a given. ECE has been really great for technical assistance.
Member Nr. 2770
Old 08-24-2009, 12:06 PM   #14
lolife99
lolife99's Avatar
I always remove them. I've never had any problems with bottoming out!?
Keith
Old 08-24-2009, 12:10 PM   #15
72BlckButy
Tot Roddin'
72BlckButy's Avatar
On my truck we have yet to reinstall the bumpstops and I haven't bottomed out once.
-Nate
Old 08-24-2009, 01:32 PM   #16
vegaschevy
you guys obviously do not live in Vegas...
Our roads SUCK!!!
Old 08-24-2009, 11:41 AM   #17
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Same old song and dance... look no further than ECE. Their prices, parts, and service is comparable to none.
Here's a shot my recently lowered (4.5/6), disc brake upgraded (6-lug rotors), '69 SWB. Check out the build thread in my signature for pictures of the install (Project: Blank Slate)
-Nate
Old 08-24-2009, 02:14 PM   #18
smoky02
Mine did, I decided to raise it back up due to it always hitting the frame.
Old 08-24-2009, 02:29 PM   #19
big_al_71
big_al_71's Avatar
I removed my frame stops as well and I have not bottomed out yet....
Here is a pict of the 4/6 with 20's rear and 18's front
Old 08-24-2009, 06:06 PM   #20
vegaschevy
you have 295/40/20 tires i think i read? what is the measurement to your bottom fender lip in the rear?about center with the tire?
Old 08-24-2009, 06:50 PM   #21
big_al_71
big_al_71's Avatar
Left front 28 1/2 inches from the ground to the fender lip ,
tire 26 inches tall 18x8 255-50-18
Right front 28 1/2 inches from the ground to the fender lip
Right rear 31 1/2. inches to the lip of the bed ,Tire 29 inches 20x10 295-40-20
Left rear 31 1/2 inches to the lip of the bed
Old 08-24-2009, 08:19 PM   #22
vegaschevy
Hmmm that does not seem like much drop from where I am at now factory. Well my tires on the rear are about 26.5" and im at 33.5 now. weird. factory springs as well.
Old 08-24-2009, 06:12 PM   #23
Becker67
Becker67's Avatar
Heres my 4/6 drop everything is ece except spindles. I made my own custom made drop a ams. Then used stock spindles.
Kevin
67 custom cab big window swb 350/700r4 4/6 drop tilt,a/c
69 custom/10 swb 350/350 4/6 drop tach,tilt
71 cheyenne super swb 454/700r4 4/6drop tach,tilt,a/c,bucket seats,speed warning
96 gmc swb
Becker67 is offline   Reply With Quote
Old 08-24-2009, 10:23 PM   #24
threeonthetree
threeonthetree's Avatar
can you get a 4'' drop in the front buy cutting the coils
i want a 4/6 but don't have the money.
i have enough to get the rear drop kit from ECE
i know it wont be that great of a ride but i want to drop the truck.
has anyone cut the coils to achieve a 4'' drop?
Smoking Tires Since 1992
1969 c10 AKA SIN
1985 SSWB TRAZER
(super short wheel base)
threeonthetree is offline   Reply With Quote
Old 08-24-2009, 10:31 PM   #25
leddzepp
Moderator
leddzepp's Avatar
I have never had any issues with CPP. Every time I hear of problems, it is always wrong parts sent, bad customer service. I get great customer service at the counter, and always walk out with the right parts. They have a nice shop, and even let my 3 yr old run around and touch stuff while I am at the counter. I buy from them because they are right down the street from me. Every local that I saw at Brothers truck show uses them also and loves them. I guess they suck at mail orders If I bought from ECE, I would have to pay shipping and sales tax as I am in California. If ECE would nix one or the other, I would try buying from them as I hear from people on the board that they are great.
Just my .02
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
