01-12-2003, 12:02 AM | #1 |
hood shaking
i have a problem when i wrecked my truck i grabbed a hood to put on the truck out of a salvage yard, well now i have the hood on and when i drive the truck the center of the hood shakes like it is just a real thin piece of sheet metal laying over the engine and shakes really bad
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
01-12-2003, 12:06 AM | #2 |
on the inside of the hood theres two supports that run from front to back. do they have some 4inch wide fillers between them and the sheet metal?
01-12-2003, 12:08 AM | #3 |
I am a Referee of life.
There are some rattle strips that fit between the X brace and the hood.They may need replacing(probably do after30+ years.These hoods are not known for their great strength in this area.I have heard of people putting cowl hoods on to get more hood stability,
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
01-12-2003, 02:01 AM | #4 |
its all about the +6 inches
Heh...I've never seen one NOT do that!
01-12-2003, 02:51 AM | #5 |
Listening since '86
Here I thought I was the only one that had the hood shake!! Personally I don't mind it! Friendly reminder that I'm not in my dinky 4cyl car!!
2007 Saturn Aura - hey it WAS a GM product |
01-12-2003, 01:06 PM | #6 |
I've had my C20 for a long time and never had a problem with it shaking. When I got my C10 I noticed it did shake quite a bit. I was figuring on having to replace the strips between the sheet metal and the braces on the underside of the hood and hope that cleared it up.
Has anybody gone as far as putting in another cross brace to add more support right in the middle of the hood?
1972 C-10 LWB, 400/350, 2WD 1972 C-20 Custom Camper, 350/350, 4WD (Converted) |
01-12-2003, 01:08 PM | #7 |
Putting the strips in should take care of it if they fit tight.
01-18-2003, 07:59 PM | #8 |
Does the 67-68 hood shake like that, they look stronger than the 69-72 hoods, this might be a dum question can a 67-68 hood fit on a 71 or is different on the front?
01-19-2003, 01:32 AM | #9 |
So Many Ideas, So Little Money
well, if you modify the piss outta it. it'd take fabbingwork, I may try this some day, that or just get a whole 67-68 clip. found this pic a while back
72 Blazer 3/4 ton running gear 4.10s NP205/TH350 350 4in lift half doors 71 C10 with 454 99 S-10 5.1L SBC 700R4 09 Malibu Marshalltown, Iowa |
01-19-2003, 11:11 AM | #10 |
My hood looked like it was going to fly off the truck it shook so bad. I not only put the new padding between the cross members and the sheetmetal but put new foam on the back and front stabilizers also. New hood bumper stops and new hood levelers and it is so rock solid it never moves at all. I think it was about 20.00 for all but worht every penny~~!
01-19-2003, 11:21 AM | #11 |
67-68n hoods don't work with the later front clips.The way most people get the laid back look in front of the hood is to pie slice the hood and lay it back.I haven't done one (no body man here) but it does look cool and only someone who really knows these trucks would notice.
