08-24-2009, 10:19 AM | #1 |
how do i hook up a vaccume guage
how do i hook up a vaccume guage to my 77 chevy with a stock 350?
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin 79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s 81 mercedes 300d 25 MPG 77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded" 73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091 '77 chevy trucks. built to stay tough. life is short build a hot rod |
08-24-2009, 10:45 AM | #2 |
Re: how do i hook up a vaccume guage
Find a vacuum port on the carb or intake. I never looked under the hood to see where the line was hooked to, just cut the hose when I took the gauge out.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
08-24-2009, 12:07 PM | #3 |
ok so ether one will work sweet
08-24-2009, 01:11 PM | #4 |
Gettin It One Pice At A Time
Uh, not quite! you will more then likely need non-ported vacuum! find where the PCV filter is connected and use that line. or there is a T fitting behind your carb for your trans *just saw that you had a manual trans so it might not be there but look anyway.*and what not and that is full vacuum. using just any vacuum port will give you false reading!
RIP ELJAY Work In Progress 1979 GMC C1500 Trailering Special. Getting the truck done, one piece at a time. “You can tell a lot about a fellow’s character by his way of eating jellybeans.”Ronald Reagan “I don’t know the key to success but I know the key to failure is trying to please everybody.” Bill Cosby Last edited by 79gmcc15; 08-24-2009 at 01:12 PM. |
08-24-2009, 11:47 PM | #5 | |
Just Not Low Enough!
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
08-25-2009, 01:09 AM | #6 |
In the Forgotten far North.
Hooking it directly to a fitting on the intake is the best thing to do so you get a true and accurate intake vaccuum reading. There may very well be an unused & plugged vaccuum port on the intake behind your carb that you can pull and install a hose fitting into.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
