Old 08-24-2009, 10:38 AM   #1
lts70
1970 Daily Driver
lts70's Avatar
Vintage Air Heater Shut off Valve Placement
Because I had a custom coil put in my vintage Air surfeit system so that I could Shave my firewall I have to figure a way to make my heater valve work. I have two option that I can figure. One is to have the valve right by the Unit itself in the cab, in-between the unit and the bulkhead that goes through the fire wall I have 12” of hose I could tap into. In that location I can use the vintage air cable by cutting it down a bit. The second spot would be underneath the battery tray, I would use a 9’ choke cable I have to make that location work. I am leaning towards the in cab option but wanted to see if you guys had any opinions.
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 08-28-2009, 05:07 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: Vintage Air Heater Shut off Valve Placement
I personally like the option under the hood as water valves sometimes leak and then it would not be in the cab.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 08-30-2009, 09:43 AM   #3
acl
acl's Avatar
I put mine underdash as you spoke about. I used a longer hose and did some looping around under there but it went well. its tight but it works. I did not want to have the cable that long. Gary
acl is offline   Reply With Quote
