Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > WIW
Old 08-24-2009, 10:51 AM   #1
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
64 c10
Alright guys I'm wondering what my truck is worth. I may be needing to sell it. Heres the break down on parts. The truck is not driving, Look at my pics and you'll see how it is. It's in our shop right now with no cab or bed on it.
64 C10 BBW custom LWB
SD raised crossmember P-51 Kit $2600 New
SD Air ride Kit $1200 New
Summit fuel cell $250 New
POL 6 lug disc brakes $600 New
350 4 bolt: Comp cam 468 Lift, stock bottem end, bored .030 over, stock heads worked with 2.02/1.60 valves, Z28 springs, Stamped roller tips, double timing chain new parts: AirGap intake, aluminum edelbrock valvecovers, edelbrock matching breathers, Holley 750 W/eletric choke, Edelbrock 110g fuel pump, mallory HEI, Mallory 8mm plug wires. $922 in new parts, not including block, cam, head work.
Turbo350 B&M shift kit, New B&M torquemaster 2400 stall $166, B&M floor shifter
AutoMeter 1902 Guages $320 New in box
Summit eletric speedo sender $55 new in box
Hooker Headers 2466HKR $150
Brake booster W/MC $350 New in box set up disc/drum
Painless 63-66 Harness $415
Tilt Column out of a Chevy van, floor shift $50
79-93 Mustang power rack and pinion. $180
Thats $7258 in new parts. I have couple hundred dollars worth of new parts in boxes I just cant think of what they are at this time.
Cab does need new cab corners, doors worked, and a couple other things. Comes with subburban buckets, Bed is pretty straight, but roll pan is dented and can be fixed. Wood bed will need to come out due to back half. I do not have a rear link system for the truck yet. Here is my photobucket http://s581.photobucket.com/albums/ss260/ruffrida2005/ It does not show all new parts, but you get the Idea.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
