08-24-2009, 11:42 AM | #1 |
Rebuild GM E-brake calipers?
This question is posted in the general "Suspension" forum, but hasn't been answered in a while, so I thought I would try here too.
I bought a 79 Firebird rear end housing, that came with disc brakes. The parts look decent, but the rubber is 30 years old, so does anybody make a rebuild kit? I've searched and found zilch. Is this not as simple as doing front calipers? Suggestions? Your wisdom is requested. -Pete |
08-24-2009, 01:25 PM | #2 |
Registered Chevy Owner
Re: Rebuild GM E-brake calipers?
I would check with your local auto parts store. Napa usually has what I'm looking for, if not in stock then they can order it. I got a complete carb rebuild kit for my Rochester on my 216 at Napa. I was suprised they had it in stock.
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
08-24-2009, 02:44 PM | #3 |
Hollister Road Co.
Are you looking for rubber bushings for the suspension or the disc brake rubber parts?
08-24-2009, 02:47 PM | #4 |
I want to replace the rubber dust shield and the o-ring/seals in the caliper itself. I haven't taken it apart yet, I didn't want to mess anything up in case there is a special way of doing it.
I've done front calipers before and its super easy, but I've heard that special precautions need to be taken with the e-brake cable, I need to research that a little more, but information is pretty scarce. Last edited by sn33kyp3t3; 08-24-2009 at 02:48 PM. |
08-24-2009, 02:57 PM | #5 |
Solved! Thanks nickp51chevy!
Here it is for reference sake: http://www.napaonline.com/masterpage...oot+Kit+-+Rear I don't know why I didn't try Napa right off the bat. Blond moment! Firebirds/Camaros don't list disc rear brakes for '78, '79, but the caddies used them and they are the same equipment. I was just asking for the wrong make. Anyway, I would still like to hear of any special precautions if anybody has any experience. |
08-24-2009, 03:09 PM | #6 |
Those calipers are not the easiest to deal with. There is a ratcheting mechanism inside to accomodate the parking brake (item 5-7 and 15 & 16 in the diagram). You may be better off just buying remanufactured.
My 51 project http://www.cardomain.com/ride/2285825 My 68 Camaro project http://www.cardomain.com/ride/2277404/1 Last edited by bretcopsey; 08-24-2009 at 03:11 PM. |
08-25-2009, 12:21 AM | #7 |
Go with reman, you will same lots of time.
Jean-Marc Lacasse 57 GMC 55 GMC 55 Belair 99 S10 http://67-72chevytrucks.com/vboard/s...d.php?t=316140 http://67-72chevytrucks.com/vboard/s...d.php?t=806011 |
08-25-2009, 05:45 PM | #8 |
Yep, go reman. that's what I did. Although one did leak at the piston before I got it on the road.
'56 truck (the never ending project) '06 Z/71 loaded (daily driver) '07 Mercedes-Benz C-Class (wife's driver) Gone: 72 SB, 67 CST, 57 BBW, 47 Panel streetrod, |
08-27-2009, 01:06 AM | #9 |
I've got time, and if I can save myself a cool $200 I'll try my hand at rebuilding these, I'll take pictures along the way and make a thread for it, that is if I succeed.
If not you all can point, laugh, and say "I told you so" ha ha. bretcopsey: Thanks for the exploded view, that will come in handy. |
08-27-2009, 09:23 AM | #10 |
I know this is for a 82-86 rear setup, but figured the instructions might help seeing as it looks pretty similar to the picture above:
