Stovebolt six identification
Gentlemen,
My Chev 1/2 ton pickup looks like it has a rebuilt engine installed. The nameplate says Forburg 235. I'm not sure it is really a 235 since the sheet metal coverplate on the sparkplug side extends to the top of the head, which I thought was only done on the 216s. My reason for wanting to pin down the engine type is that I need to replace the failed electric fuel pump with a mechanical and the 216 and the real 235 have different pump part numbers. can anyone set me straight on this? Thanks, Bill |
Registered Chevy Owner
Re: Stovebolt six identification
What is the block casting number? And pictures might help.
Love is fleeting, but Chevy trucks are forever!!!! ![]() 1970 Chevy CST C10 long box 350/400 ![]() 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
Hollister Road Co.
Bill you can also try the stovebolt.com they have some good info on old GM 6's, But 235's didn't have the sheet metal all the way up as far as I know
Nick,
The number behind the distributor is: JBA23603. The Forberg nameplate is almost impossible to read except the rebuild date (1988) and the crank undersizes. There is another number that looks like 231, but the title is not readable. Any help? Again, I thought that the side coverplate on the 235 exposed the head and plugs. Any idea if there would be a problem with exchanging fuel pumps between engine sozes? Bill |
Hollister Road Co.
look below the dist for a number cast into the block it should be 6 to 8 digits long. and yes 235 had exposed plugs.
Looks like my engine is a 216. Will the same mechanical fuel pump fit both the 216 and the 235, or are different pumps required?
Bill |
