Old 08-24-2009, 12:46 PM   #1
Dustydog
Dustydog's Avatar
Wheel Base 70 SB - U-Haul Trailer
I am picking up a 1970 GMC Shortbed truck and will be towing it home with a U-Haul trailer. Just wanting to make sure it will fit on the trailer?
Thanks,
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Dustydog is offline   Reply With Quote
Old 08-24-2009, 12:56 PM   #2
Ackattack
Ackattack's Avatar
Re: Wheel Base 70 SB - U-Haul Trailer
I put my 68 SWB on a u-haul trailer when I took it to get painted. It was a tight squeeze width wise. The tires had to kindof driver over the outer edges.
My truck has disk brakes on it with rallies (for now).
Ackattack is offline   Reply With Quote
Old 08-24-2009, 01:29 PM   #3
vegaschevy
I picked the truck up in my build thread and it fit on a uhaul car hauler no problem...
go to projects and go to NOT4SLE
vegaschevy is offline   Reply With Quote
Old 08-24-2009, 02:09 PM   #4
Dustydog
Dustydog's Avatar
Thanks,
we are heading out Tuesday night to pick it up. 1400 miles each way!
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 08-24-2009, 02:48 PM   #5
Hart_Rod
Hart_Rod's Avatar
Stock wheels will fit on the trailer no problem. If the truck has a dished aftermarket wheel, that's usually what causes problems.
Hart_Rod is offline   Reply With Quote
Old 08-24-2009, 03:03 PM   #6
Boomerswany
Retiredoldfarttankerguy
Boomerswany's Avatar
Hart Rod's, right on the money. I drug #6 from Spokane on a u-haul - it was a LWB 4X4, but the narrow wheels and tires saved me. So have Fun. 1400 miles that's committed! either you are or should be!
________________________________
Swany
Current 67-72 truck projo - #5 of 6 and #1,000,000... of all the other things that keep me from working on it.
Fav - local parts shop. They ship world-wide. www.fillingstation.com
Boomerswany is offline   Reply With Quote
Old 08-24-2009, 03:09 PM   #7
Dustydog
Dustydog's Avatar
Thanks,
I think it may be to wide with the wheels that are on it now. But he has a set of stock wheels/tires that I can swap out.
Dustydog
1940 Ford 2D SDN
1970 GMC SB
2004 C5 Vette
Old 08-24-2009, 04:21 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
1400 is a good day trip!
Old 08-24-2009, 04:26 PM   #9
BCOWANWHEELS
They make 2 different width car trailers u-haul uses. Try to get the wider one. Also dont tell them your gonna haul a truck or they wont rent it to you, tell them its for a jeep with wide tires and lastly dont go over 55mph as it will start swaying with you and it will jack-knife you. It will handle the weight with no problem. Make sure you chain it down real good, side to side & front to back. Better safe than sorry.
Bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-24-2009, 09:31 PM   #10
sighlurr
______________
sighlurr's Avatar
Bob
1970 Datsun 1200, everytime.
Their weight limit is 4900 lbs, I learned this last night.
sighlurr is offline   Reply With Quote
Old 08-24-2009, 06:31 PM   #11
mikey531
mikey531's Avatar
I used a u-haul trailer to get my truck with no hauling problems. Again DON"T tell them it is for a truck! I told them it was 69 Nova. I also used one to haul my 94 Corvette to New York and I may have exceeded the posted speed limit with no problems swaying. However stop and check your chains/straps frequently.
mikey531 is offline   Reply With Quote
Old 08-24-2009, 08:25 PM   #12
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
Yep, by their rules, a 3/4T truck is too light to pull a Cherokee. I've brought home several '87 Accords in the last few years.....
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 08-24-2009, 08:49 PM   #13
leddzepp
Moderator
leddzepp's Avatar
I am making a road trip next Saturday to pick up my new "project" and am renting a U-Haul car trailer. I told them it was for a 03 Civic.
1400 miles is a haul. Mine is only 500 each way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 08-24-2009, 08:59 PM   #14
BCOWANWHEELS
Yes it will fit no problem. I,ve hauled longhorns on u-hauls before
