Old 08-24-2009, 03:48 PM   #1
sgtusmc
sgtusmc's Avatar
s10 AD swap wire diagrams
I've been asked a few times if I had any wire diagrams for the s10 swap. When I did my swap I didn't cut any wires. I carefully disconnected everything out of the s10's cab. I had to cut up some of the s10's sheet metal to get all the wiring out in one piece. I crawled under the bed of the s10 and disconnected all the wiring. Once the AD sheet metal was mounted I connected all the s10's wires back. I did however, splice into the s10 gauge cluster. I needed the volts, water temp, oil pressure and fuel. The s10 I used was a 1988 with a 2.8. I've been asked about the 4.3. I didn't use a 4.3 but the diagrams might be close as far as wire colors go. I used www.alldatadiy.com for all my diagrams. They charge around $20 a year. It's vehicle model and year specific. So if your doing a 1996 s10 swap with a 4.3 you will get that years diagrams for that truck and engine. There's a lot of good info there. Here's some of the diagrams I have saved. Feel free to add any diagrams you have.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 08-24-2009, 03:51 PM   #2
sgtusmc
sgtusmc's Avatar
Re: s10 AD swap wire diagrams
Old 08-24-2009, 03:54 PM   #3
sgtusmc
sgtusmc's Avatar
Old 08-24-2009, 03:56 PM   #4
sgtusmc
sgtusmc's Avatar
Old 08-24-2009, 04:04 PM   #5
53GMC
53GMC's Avatar
When I say thank you....that does not say it all..but THANK YOU!! that will be great help to me as i go into this project further! its good guys like you that make projects like this enjoyable!
thanks,
53GMC
53GMC is offline   Reply With Quote
Old 08-24-2009, 11:07 PM   #6
50Bow-tied GMC
Wow! Thank you very much for posting this information. When finances arent so tight I hope to get started on my 51 and I plan on doing an S-10 frame swap and had some questions about reusing the existing wiring on the frame. It appears that I will be able to use most, if not all, of it. I also plan on putting in a V-8. I am assuming by your post that you used on also. Was it very difficult to make the conversion from the 2.8 to a V-8?
50Bow-tied GMC is offline   Reply With Quote
Old 08-25-2009, 01:06 AM   #7
nickp51chevy
Registered Chevy Owner
nickp51chevy's Avatar
Sgt used the 2.8.
Love is fleeting, but Chevy trucks are forever!!!!
1970 Chevy CST C10 long box 350/400
2008 Chevy Silverado short box 4x4
Had;
1951 Chevy short box 307/T5
1988 Chevy shot box 4x4 350/350
1971 Chevy C10 long box 4x4 350/350
1971 Chevy C20 long box 350/350
1971 Chevy C10 long box 350/350
nickp51chevy is offline   Reply With Quote
