Old 08-24-2009, 05:41 PM   #1
djw32
Ground strap inside the tran tunnel?
What should the ground strap in the upper portion of the trans tunnel be grounded to?
David
djw32 is offline   Reply With Quote
Old 08-24-2009, 06:03 PM   #2
John Fabris
TOTY 2006
John Fabris's Avatar
Re: Ground strap inside the tran tunnel?
Engine, or more correctly, bolt it to passenger head via one of the bolt holes on end of head, or to one of the Transmission bellhousing to engine bolts. (assuming you are talking about firewall section of trans tunnel).
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-24-2009, 06:20 PM   #3
djw32
Originally Posted by John Fabris View Post
Engine. (assuming you are talking about firewall section of trans tunnel).
Yes.
Old 08-24-2009, 06:41 PM   #4
John Fabris
TOTY 2006
Updated my previous post.
John Fabris
67 C10 SWB
Old 08-24-2009, 10:45 PM   #5
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Here's how I did mine.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
