Old 08-24-2009, 08:02 PM   #1
vegaschevy
suggestions on fuel line fitment
I have this new carb i am finally getting around to installing. The fuel inlet is a dual feed set up and the supplied bracket hits the AC bracketry.
I see one of a couple fixes.
A. Put a carb spacer under the carb which may work and provide enough clearance.
B. bend the fuel line a bit which would give it a 45* bend and clear the bracket. (seems like the best)
C. find a flexible fuel line.
If I go with B is their a tubing bender small enough to fit in the available short arm to bend it out accurately on both arms?
DoeS anyone else have a suggestion?
vegaschevy is offline   Reply With Quote
Old 08-24-2009, 09:11 PM   #2
hayhauler71
hayhauler71's Avatar
Re: suggestions on fuel line fitment
I like the 1 inch 4 hole carb spacer option. 1 the spacer will help out with clearance 2 it will keep the fuel in the carb from boiling. Just my 2 cents worth.
hayhauler71 is offline   Reply With Quote
Old 08-24-2009, 11:34 PM   #3
vegaschevy
thanks for the input,
anyone else?
Old 08-24-2009, 11:48 PM   #4
GruntMoanCough
GruntMoanCough's Avatar
Plus, you'll get a little more HP.
I ran into this problem with a SBC (with a Barry Grant carb), ended up shortening the two lines that go to the float bowls but, I can see that the choke coil is in the way on yours.
I think that bending the two lines would be a good idea, also.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 08-25-2009, 01:43 AM   #5
BCOWANWHEELS
Can you flip the line 180 degrees and feed it from the back ?
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 08-25-2009, 04:29 AM   #6
El Jay
Gone to greener pastures
Don't laff at me: if you decide to bend it & can't find a bender to work, fill the lines with sand and then bend them.
That will prevent the lines from kinking.
Just be sure they are really clean before you put the line(s) in service.
On the top end of the HP curve, it'll probably lag a bit on the bottom.
Personally, I'm more interested with torque rather than HP.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 08-25-2009, 05:32 AM   #7
cdowns
cdowns's Avatar
are those tubes regular steel or stainless? stainless will be a bit difficult to bend
i like the spacer option
another option is a 45 fitting on the carb
Old 08-25-2009, 07:50 AM   #8
Green Machine
Green Machine's Avatar
How about this ? Half inch insulated spacer. I run this type on two of our trucks to keep the fuel cooler, you likely will want some insulator or the fuel will boil causing hard hot engine starts. You will need a paper gasket on both sides of any spacer, but you should be able to use the thick gasket you have on there if you need a hair more room. And I like the spacer option because it is something you can undo easily if you don't like it. Plenty of room under the hood, and many engines like a little spacer anyway.
http://www.summitracing.com/parts/SUM-G1402/
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-25-2009, 09:04 AM   #9
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Carb spacer, quickest and easiest.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 08-25-2009, 11:43 AM   #10
big_al_71
big_al_71's Avatar
+1 on the carb spacer!!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 08-25-2009, 01:55 PM   #11
mclairmo
Don't bend that line or you may end up wth peeling, cracking and flaking chrome. Use a carb spacer, will probably help with power and keeping the fuel cooler, too. You can find them cheap on Ebay and some even have a threaded hole for a power brake booster or pcv nipple, which is nice to have it you ever need it.
mclairmo is offline   Reply With Quote
