Old 08-24-2009, 08:31 PM   #1
61TWUK
61TWUK's Avatar
keep 10 bolt or go 12
When I get ready to upgrade my rear end should I keep the 10 bolt or should I go to the 12 bolt? I like the look of my "pumpkin" and really... there is not a hugh benefit to swapping... what do yal think?
1961 Apache
SWB/SBW for now...
Built 327
You need two tools in life: duct tape and WD-40. If it moves and it shouldn't, you use duct tape. If it doesn't move and it should, you use WD-40.
61TWUK is offline   Reply With Quote
Old 08-24-2009, 09:09 PM   #2
BMSJaX
BMSJaX's Avatar
Re: keep 10 bolt or go 12
Well the 12 bolt is suppose to be a stronger/better rear end, comparable to the ford nine inch... If you got one layin around or are gettin it for free then sure go for it, its the better rear end. If your gonna buy one and arnt lookin to do anything more than daily "spirited" driving then the 10 bolt should be fine, especially if you like the looks better
1964 Chevy C10 a.k.a. Julie Ann
H.E.I. cause its better to be pointless
BMSJaX is offline   Reply With Quote
Old 08-24-2009, 09:14 PM   #3
61TWUK
61TWUK's Avatar
I do have a 12 bolt handy
1961 Apache
SWB/SBW for now...
Built 327
Old 08-24-2009, 09:16 PM   #4
BMSJaX
BMSJaX's Avatar
Then ya, I vote go with the 12 bolt
Old 08-25-2009, 12:35 AM   #5
Captainfab
60-66 Nut
I believe you will have more gear and posi/locker options with a 12 bolt as compared to your 10 bolt.
Old 08-25-2009, 12:53 AM   #6
62 Longbed
62 Longbed's Avatar
SINCE I HAVE A 62 , I LIKE THE PUMPKIN ALSO .. BUT NO CHOICE OF GEARS ... I'M GONNA USE A REAREND OUT OF A SUBURBAN SINCE I WANNA KEEP THE 6 LUG WHEELS , THE BRAKE PARTS WILL BE CHEAPER , LARGER SELECTION OF GEAR RATIOS , FINDING ONE WITH A POSI AND MAYBE 3:73 OR LOWER GEARS IS PROBABLY EASIER ... I WILL HAVE TO TAKE IT IN AND HAVE THE MOUNTS CUT OFF AND MINE OR SIMULAR , MOUNTED BACK ON AND ANGLE SET WITH INSTALL .. JUST AN IDEA ..
62 Longbed is offline   Reply With Quote
