Old 05-20-2002, 03:35 PM   #1
68gmcjon
Got earplugs?
68gmcjon's Avatar
Post smoke
When i'm just going down the street my truck smokes, it's not that bad but i just wonder if it's normal or not.
1968 GMC
Original A/C, bucket seats, PS,PB
396 bored to 402, Dynomax cerama-coat headers, Super 40 Flowmasters, 272/284 Crane cam, Crane gold roller rockers, holley 750 cfm double pumper, Edelbrock Performer RPM intake, HEI ignition, 9.5:compression
Alltogether 411HP and 446ft/lbs
Dana 60 w/ 3.54 gears
Turbo 400 tranny
Why would you have anything other than a big block? HAHA
68gmcjon is offline   Reply With Quote
Old 05-20-2002, 03:37 PM   #2
COBALT
COBALT's Avatar
Post
1. What color is the smoke.
2. Is it out both pipes or just one.
3. Is it all the time, or only under acceleration? What about heavy loads like driving up a steep hill?
'69 3/4 ton C20 2wd w/ 350ci/400THM and a wood bed!
'69 3/4 ton Custom 20 2wd w/ ORIGINAL 350ci/4sp Manual and a wood bed (parts beast).
Seattle, WA.
*See pics of my trucks and project at www.webshots.com!
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 05-20-2002, 08:21 PM   #3
68gmcjon
Got earplugs?
68gmcjon's Avatar
Post
blueish color
when accelerating
1968 GMC
Turbo 400 tranny
Old 05-20-2002, 11:28 PM   #4
COBALT
COBALT's Avatar
Post
Sounds like you're burning oil.
Your head(s) may need valve work. Valves seals are letting oil into the cumbustion chamber, and is burning up with the fuel. That involves pulling the head and taking it somewhere to have it done unless you know how, or you get a new head.
The other thing could be that your rings in your pistons are not sealing right to the cylinder wall, and oil is being thrown up from the crank. I don't know if this could even happen, but if it were the case then you'd be loosing compression on the offending cylinders, which means you'd be loosing power.
Come to think of it if it's happening on acceleration then your valves are probably the culprit. Highest compression and highest oil pressure...
I guess I'm assuming this is a V8, but is it a straight 6? If not then is the smoke comming out both tailpipes?
Seattle, WA.
Seattle, WA.
Old 05-20-2002, 11:35 PM   #5
Zkast
Zkast's Avatar
Post
Pull the plugs and note the condition of each one and where it came from. Pay close attention to the back 4 cylinders if its a V8.
You'll be able to tell alot of whats going on by how the plugs look. If you see a suspicous looking plug, take a shot of it and post it
Pictures and more...
piston@zkast.com
'71 LWB
350/350T, PS/PB
Special options? Yes, RUST... Need some?
Webmaster/Team owner
www.zkast.com
Garrett - Olathe, Kansas
Zkast is offline   Reply With Quote
Old 05-20-2002, 11:52 PM   #6
SWINGSAX68
Now the others dig........
SWINGSAX68's Avatar
Cool
These guys are right.....and/or the heads must be in need of a good machining. Have the pistons checked in the block (I think thats what they are called). The heads of the Pistons may be worn. This would then lead to an overhaul, like my 307. But then I don't know a whole lot, so go to these other guys for more detailed advise.
IN A TUX WITH A 68 BOWTIE.
*SELLING FOR PARTS*
"P.O.S" Stepside 68, Primed from Fl., rusted out a bit, but
*SELLING FOR PARTS*
Interested? E-mail me!!
"Rusty" Stepside 68 Brown/Black (not by choice, soon to be charcoal grey)
This is my baby, just put in wood bed.
Overhauled 307.
Just needs the brakes to be redone then its ready to run.
Oh yeah, My girlfreind's got a 63 named "Blue Boy"
68 Chevy C10 Stepside Black Primer
78 GMC Longbed White
09 Chevy Silverado Shortbed Granite Blue
LOOKING FOR A 67 4 DOOR IMPALA!!!Just like Sam and Dean Winchester!! 'Cause Mustangs are for p^**#$ and you can fit a body in the trunk of a 67 Impala
MEMBER OF THE DRUM BRAKE CLUB
Bachelor of Music in Jazz Studies Texas State University-San Marcos, TX
Certified Music Educator
I hope Mom is up there watching and being my Guardian Angel
"I've got a fever.....and the only prescription.....IS MORE COW BELL"
-The Legendary: Bruce Dickenson
"F#$@ 'em up!!!!!!"
-The Legendary: Rogelio Escobar
TRUCKY LINKS
http://67-72chevytrucks.com/vboard/s...d.php?t=457750
http://67-72chevytrucks.com/vboard/s...d.php?t=461184
http://67-72chevytrucks.com/vboard/s...d.php?t=472848
http://67-72chevytrucks.com/vboard/s...d.php?t=417541
http://67-72chevytrucks.com/vboard/s...d.php?t=477788
SWINGSAX68 is offline   Reply With Quote
Old 05-21-2002, 12:59 AM   #7
dmnall
dmnall's Avatar
Exclamation
Could be that your Valve Seals are worn out but if you are going to take your heads off you might as well have New Valve Guides and have a complete valve job done to the heads. Also before you do pull the heads, check to make sure that your plugs are not fauled and then also do a compression check because if you are going to take the heads off, you might as well (depending on how many miles is on your block) do new rings and bearings!!
Truck #1 68 Chev LWB Fleet w/ Wood Floor (Sucks Gas and Hauls Ass!) and in process of Body Work...
Truck #2 1994 GMC Sierra SL w/ 4.3L Vortec V6, 4L60E Auto!!
1968 C10 Truck LWB Fleetside
1968 C10 Truck SWB Stepside
1994 K2500 Ext Cab Fleetside
2008 Honda Civic Si *lease*
dmnall is offline   Reply With Quote
