Old 08-25-2009, 12:57 AM   #1
anythingonwhlz
double wall top mounting hardware
I need help getting the correct bolts to mount my double wall top to the side panels. I bought a 1970 and all the bolts are missing
Any help is appreciated
anythingonwhlz is offline   Reply With Quote
Old 08-29-2009, 06:53 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: double wall top mounting hardware
The side panels and top mount separate? do you need the screws for the side panles or the bolts for the dog ears on the back of the top?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-29-2009, 10:14 PM   #3
anythingonwhlz
Not the bolts on the header panel or the bolts for the rear hold down. Just the bolts that run along the side panels
Old 08-29-2009, 10:22 PM   #4
Thealien
Thealien's Avatar
I believe they are 5/16 X 18. I am not sure about the length either maybe 1 1/4 or 1 1/2" long. When I took mine off I ran a tap in all my mounting holes and then bolted the top to a 2X4 frame so it wouldn't spread. I put never seize on the bolts so I will be able to get them out some day. If you look at the bottom of your top you will see the bolt holes and should be able to tell the correct size and be able to determine the length you need.
Old 08-30-2009, 12:12 AM   #5
FRENCHBLUE72
PROJECT 7DEUCE
I used carb stubs so that I could line up the holes better....
MEMBER #6377
Project "7DEUCE"
Old 08-30-2009, 08:49 AM   #6
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Neat trick
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 09-12-2009, 01:40 PM   #7
VanceH
Loving the Jimmster
VanceH's Avatar
Does anyone have pics of this topic i have never removed the top and i want to!!!!!
VanceH is offline   Reply With Quote
