08-25-2009, 12:59 AM | #1 |
1965 chevy 4x4
Greetings
What is stock from the factory for the axles and t-case in a 65 chevy 4x4? |
08-25-2009, 01:06 AM | #2 |
60-66 Nut
Re: 1965 chevy 4x4
If it is a K10 then the axles will be a Dana 44 closed knuckle up front and a 12 bolt in the rear. The T-case would probably be a Rockwell T221
If you have a K20 the main difference would be the rear diff. It could be either an Eaton HO52 or a Dana 60
