TruckincrazY
New shackles, No change?
I just put on some DJM 2" shackles. They weren't hard to do. The problem is my truck seems no lower than before. Anybody else have this problem?
a fool with no money
Re: New shackles, No change?
stick the old shackle next to the new one... possibly, a P.O. already did the swap?
also, your shock might be bottomed out
Basicly stock 83 SWB with a few Bolt-ons before, during and still during http://photobucket.com/albums/y251/moostifer/truck/ http://photobucket.com/albums/y251/moostifer/motor/ Last edited by Moostifer; 08-25-2009 at 11:44 AM. |
67-72 parts collector,…
![]() Join Date: Nov 2002
Got any pictures?
Or - did you do all four shackles?
If you only did two, like just the rear ones, then you will only see half the amount of drop (ie, 1" - which might be harder to notice). K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
TruckincrazY
Hmm...I did just change out one shackle since I was in a hurry. Perhaps changing out the other ones will bring it down to where I want it. I just put on 3" spindles and want to keep the staggered look. I will try and put the other shackle on and post the results.
#6 | |
I agree check the shocks man or the bump stops too its possible.. if they are like most there is a 1'' hole and a 2'' hole for adjustment. so you might be in the 1'' hole Last edited by cobb; 08-25-2009 at 01:31 PM. |
TruckincrazY
I got the other shackle on and I think I found the problem. I had notched the crossmember for the bed, but there was just a little piece of metal hanging up. I jumped up and down on the bed to clear it up
I have car A.D.D.
Cool, looks good. Glad to see that somebody can be happy with a subtle drop. (For some reason, I can't.
-Gerald Building vehicles in memory of the first "car guy" I ever knew, my Grandpa. Bob Dunham 1935-2009. Rest in peace. 61 GMC Suburban SOLD The 86 build thread SOLD Are you a Colorado member?Click here. Last edited by Driveway Dreams; 09-03-2009 at 01:10 PM. |
I see a flip kit and some lowering springs in your future,...
#10 | |
Kameron YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY I'm a Middle ClASS HOLE 07.5 Dodge 3500 CTD -- Daily 73 C10 Factory BB SWB 2WD |
Happy to be here
![]() Join Date: Mar 2000
Nice hot rod rake you got there....
TruckincrazY
Thanks guys! It's been a long time coming. I like the stance and figure I can always add hangers if I get the itch. Next is deciding whether to go with 17 or 18" wheels. Body and paint, brake upgrade, sport bumper, etc, etc, etc. I will eventually put together a build thread once it's "finished."
#13 |
so you have 3 inch drop spindles and 2 inch drop shackles? i'm only curious because i have same kit from bell tech sitting in a box, and your stance is exactly what i'm after.
![]() also, what size tires are those?
Greg 1974 GMC 1/2 Ton SWB Fleetside L33 5.3/4l65e .................__
............._____l __\__ ..............l_(O)_ l___(O)] |
#14 |
TruckincrazY
Yep, 3" DJM Spindles and 2" DJM shackles. I have hangers but will probably send them back. I don't want the truck to be level. I was thinking of using the hangers then only using the 1" holes on the shackles, but I like it the way it is. The tires are 235/75/15. I am thinking of going with 255/55/18 or 255/60/17. Time will tell. Thanks!
#15 |
did you have to pull the bed to add the new shackles and notch out the bed frame rail?
#16 | |
TruckincrazY
