Old 08-25-2009, 02:18 PM   #1
Rockogrease
engine question
i have a 235cid strait
it sputters on the freeway only in 3rd gear, HIGH rpm in 1st and 2nd ok but even moderate cruizing speeds in 3rd sputter what could do this?"
Rockogrease is offline   Reply With Quote
Old 08-25-2009, 02:22 PM   #2
originalJD
James
originalJD's Avatar
Re: engine question
Clean up (or replace) and reset the points. Try new plugs and wires. Check exesive wear or cracks on the the rotor and cap on the distributor.
Never crush'em. Restor'em or recycle'em. The payoff is always worth it in the end.
http://viewmorepics.myspace.com/inde...lbumId=1709080
http://s258.photobucket.com/albums/h...e_top_view_all
originalJD is offline   Reply With Quote
Old 08-25-2009, 02:49 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
Re: engine question
try changing the fuel filter. After that see if your screen on your sender is not clogged. That would be in the tank.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-26-2009, 09:50 PM   #4
Rockogrease
Re: engine question
the ponts, rotor, cap, condenser, plugs, are all new
Old 08-26-2009, 11:52 PM   #5
Chevy Fleetside
Re: engine question
OK... Try changing the fuel filter. You don't even have to change it. Just take it off and blow through it and see if is restricted or not. YOu should be able to blow through it like a straw. Wipe it off first of course.
