08-25-2009, 06:35 PM | #1 |
Manual Trans question
I just bought a 69 3/4 ton 4X4 Chevy pickup with a 327 and a 4 speed with granny gear. I drove it up and down the road and running about 3000 rpms at 40 mph. Clearly this is not a useful driving range. I am wondering if i bought a 5 speed manual out of a early to late 90's gm would it bolt up to and work with my 327. Also the numbers off the 327 came back that its a 350hp 327 out of a 1965 corvette. Anyone have any thoughts??
Thanks Ryan |
08-25-2009, 06:50 PM | #2 |
Ex-Minitrucker
Re: Manual Trans question
fourth gear should be 1:1 like every other non-overdrive transmission I would blame the differential gearing. 3/4 ton is probably geared for pulling more than going fast. (Its just a 3 speed tranny with a granny low)
08-25-2009, 09:31 PM | #3 | |
70 Chevrolet=Obsession
OOPS! Just noticed that you said you have a 4X4 so you'll have to change the ratio of the front end too. Bummer...
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) Last edited by unclewatts; 08-25-2009 at 09:34 PM. |
08-25-2009, 09:33 PM | #4 |
There is also a good possibility if it is a stock tach, that your tach readings are off a fair amount. These tachs are not known for being real accurate.
08-25-2009, 09:59 PM | #5 |
Just Not Low Enough!
does it sound like 3000 RPM??
sorry had to ask..
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
08-25-2009, 11:11 PM | #6 |
its all about the +6 inches
do you have a tach, or are you just guessing at the RPMs?
you should have a 4.10 or 4.56. which would but yout 3000 RPMs closer to 70, or 60 prospectivly. |
08-25-2009, 11:19 PM | #7 |
I would definitely check the diff gear ratio's. I pulled a 5:13 out of a 3/4 and replaced it with a 4:56 gear . Then at least I could get it up to speed.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
08-25-2009, 11:54 PM | #8 |
also depends on tire size, 4.88 and 39"s are perfect for a healthy small block.
4.88 and 29" are perfect for a briggs horizontal crank 5hp. |
08-26-2009, 12:15 AM | #9 |
...but to answer your original question, you can put a later model tranny in there, but you will have clutch linkage issues, and speedo issues to work out.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD Click here to support the board Philippians 4: 6-7 |
08-26-2009, 12:34 AM | #10 |
Big Red - Now its a SWB!
wow, someone with lower gears than me! LOL. I have 4.56 and 31 inch tire in mine and it does about 3000 at 60 mph (this is a guess because I have no tach, but the math says I'm about right). I plan on going to a 3.73 gear and changing to a 5 speed like you mentioned. Sorry that I don't have an answer on your original question, but I know that others have done the swap. hopefully they will chime in. Good luck!
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
08-26-2009, 06:42 AM | #11 |
As stated above, if you are looking at a factory tach, there is a 99% chance that it reads at least several hundred rpm high at higher rpms.
Tim |
08-26-2009, 09:26 AM | #12 |
This was my first thought, too! When I bought my truck I thought I had 10:1 gears in it!! The dang thing was SCREAMING on the freeway, according to the tach. I hooked up a secondary tach and realized the factory unit was off by as much as 800 RPM!! Of course, I was still doing 3000 at 70, but it's better than 3800!
08-26-2009, 09:51 AM | #13 |
GM ran the SM420 till '67 and in '68 started running the Muncie 465 4-speed (also a New Process NP435)....all are granny four speeds. Either way they are both pretty much unbreakable units, and if you are planning on using the truck for towing, etc. I (if it were me) would not replace them. This is information I found before we swapped a 5.14 rear to a 4.10 in 72Freaks '68 dually and he's getting about 10 mph...with the Muncie 465. I think there are also 2 different SM420 and one of them is geared even lower. Check you SPID or try to ID what you have before changing it out, maybe a different rear end is what you are looking for?
Rottenwood Garage 1970...71...72 C1500 aka Orange aka Sideshow Bob 540 BB Straub Roller Cam, AFR Magnums, XP 950, TKO 600 2 Tons of Fun Last edited by OrangeCrush1970; 08-26-2009 at 09:53 AM. |
08-26-2009, 01:37 PM | #14 |
I would determine your gear ratios and calculate your rpms off that, your tire size and what mph you want to drive. It would be even better if you could determine how close your speedo is off of a hand held GPS. I felt the same as you when I first got my 67. It has 4.57 gears and a 250 straight 6 and I thought I needed a NV4500. The first thing I did was add a muffler and that made me feel alot better. Then I just got used to it. The 33" tires help some too.
My 67 has a factory tach and I am sure it is a good bit off. For one thing it seems to read differently if the lights are on. My speed is probably off too. A while back we calculated the fuel economy off the odometer and how many gallons of fuel we put in and it was hair over 14 mpg. Now understand that the speedo could be off and also it was my dad driving and he takes her pretty easy. But I do know my 67 K20 with 4.57s and a 250 gets better fuel economy than my 72 C10 with 3.73s and a 350.
Currently truckless, previous trucks: 67 K20, 87 K10 aka V10 & 72 C10 |
08-29-2009, 08:22 AM | #15 |
