08-25-2009, 07:18 PM | #1 |
Rack & pinion upgrade for my 72 c10
Could anyone help me with a rack & pinion upgrade for my 72 chevy c10 with a stock cross member. Is there a upgrade kit i can use? How about a list of parts that will work?
Thanks for the help! |
08-25-2009, 07:42 PM | #2 |
Re: Rack & pinion upgrade for my 72 c10
only ones i've seen are with custom crossmembers and suspensiuon // i hope you've got extensive fabrication and engineering skills to tackle this job
08-25-2009, 08:36 PM | #3 |
IIRC a Thunderbird rack is what a lot of people use. But like cdowns said I hope you have good fab skills.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
08-25-2009, 11:11 PM | #4 |
Yes It's definitely a task to install on a stock crossmember. I'm going to attempt it on mine. Once I start I'll need to finish it off. I have a power rack from a Mustang I used to own Long time ago. I bought it new in 95 and never put it on the car.
There are a couple of guys on here that has already done this swap. You might do a search to see what comes up. I know for a fact someone in the 55-?? forum did it, he used a front crossmember from a 67-72 truck and installed R/P steering on it. He was nice enough that he sent a cd with all the pics and details from his project to me. I've still got it here somewhere.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 08-25-2009 at 11:15 PM. |
08-25-2009, 11:52 PM | #5 |
Enjoying left field
Check out a center steer unit. This ones out of a Dodge intrepid. I think about a 94.
[IMG][/IMG] The center steers move more than a mustang II, and you can make your inner pivot points be wherever you want to eliminate bump steer. The bar behind the rack is just temporary so I can move it around. Just do your research cause some of the center steers are a rear steer setup so they're backwords. |
08-26-2009, 06:43 PM | #6 |
thanks.
Barry B could you send me the pics? Thanks |
08-26-2009, 07:16 PM | #7 |
laying low
I have concerns on whether or not the r&p steering units off smaller cars are strong enough for one of our sized trucks to hold up for very long, especially on those running large by wide wheels n tires and a DD too. I don't see the advantage of the r&p design over the conventional power sectors.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
08-26-2009, 07:23 PM | #8 |
thanks Clint could you send more pics
08-26-2009, 07:53 PM | #9 | |
I don't think r&p gets you a whole lot for the cost but one advantage is in bump steer. It get rid of alot of it |
08-26-2009, 09:37 PM | #10 |
Yes I can, but give me alittle while to find them. Maybe this weekend. PM me to remind me if I forget , which has been known to happen.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
09-20-2009, 08:16 PM | #11 |
optomistic ah-so
This thread doesn't look half as old as most that get dragged up...
...that Intrepid rack looks interesting. What pump pressure (regular GM, I hope) does it seem to like? What rack did you choose, dnd? Progress report?
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
03-17-2010, 06:09 PM | #12 |
Again -Second gen dodge dakota is supposedly got the right inner knuckle spacing in relation to the upper-lower a arm pivot points.
03-17-2010, 07:01 PM | #13 | |
"NO PROBLEM" Of course if you plan on putting a half ton of crap in the bed or pulling a 10 ton trailer with 10% tongue weight you better follow Boog's advice and get a different unit! |
