![]() Join Date: Nov 2006
Where to buy front sway bar mounting brackets
I need a set of front sway bar mounting brackets that are for lowered trucks. Anybody know who sells just the brackets ( 2 )
bob in tn. 423 384 8938
I BELIEVE IN JOHN 3:16 |
Re: Where to buy front sway bar mounting brackets
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Okay, my link didn't work, but just chose "sway bars and components" in the select catagory box on the left, they're $19 a pair.
Thanks just what i needed
I think CPP has them, too.
Thanks for the link. I need to get some of those as well. But with drop spindles, do you use the stock or lowered brackets? Reason I ask is that I'm led to believe that you use everything stock with drop spindles.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
Use the lowered, more ground clearance.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
x2
For spring & spindle combo drops (5-6") up front, you can mount the sway bar directly to the frame rails & skip those brackets. You gain the benefits of the sway bar w/o the interference issues.
Cool. That makes sense, and the lowered ones are much cheaper than the stock.
Boy that is a great idea. My 72 is low so i,am gonna give that some lookin into.
Thanks for the frame mount tip. Bob
I've done all of mine that way w/no problems. Both small & big bars, mounted in Energy Suspension poly bushings/brackets (get the p/n's w/the zerk fittings so you can grease them).
#13 |
I JUST BOUGHT A SET OF NEW MOOG brand bushings and come to find out there poly. i got them from oreilly's too. bet i could put a grease zerk in the mounting brackets and drill a small grease hole in them. do they squeek or something with no grease ?
#14 | |
If they get dry & dirty (meaning see a bunch of miles) they can get squeaky. The Energy Suspension bushings w/the zerks are actually fluted on the bushing itself to help transfer the grease.
#15 |
what is the part number of the energy susp. with the zerks
#16 |
VA72C10
![]() Join Date: Mar 2008
So with bags and spindles, this is the best solution and not the lowered mounts? Is there a recommendation of where to mount them on the frame?
Looking for a 67-72 swb or blazer project in or around VA. ![]() Last edited by VA72C10; 08-28-2009 at 12:55 AM. |
#17 |
My set-ups have consisted of cut coils w/spindles. I bolted the bar to the a-arms & used a jack to raise the center of the bar until the mounts rested solidly against the frame rails. I then marked the C/L of the holes & drilled.
I can't say 100% on the bagged installation. I swapped to a different bar & different front arms when I went through changes on my front suspension a while back & the truck never made it back on the road. I don't see any reason why it wouldn't under similar circumstances (limited/normal suspension travel). There could be an issue w/extreme travel. Best solution? That's purely subjective. I don't see the need in buying something if I don't need it. This method has worked well for me so far. I did my 68 & 74 both like this. My current build will also be done this way but it will be bagged all around. I'll get back to you on functionality then.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 08-28-2009 at 09:13 AM. |
