rear seat mounting pictures
I am looking for some pictures of the factory rear seat mounting locations, hardware and reinforcing plates. My truck never came with a rear seat, but I did get one, as well as some of the plates and floor sections, but want to see what it looks like in the factory locations. Thanks.
1970 Blazer 350/SM465/205 SOLD! | 1998 Z3 |
![]() Join Date: Jan 2007
Re: rear seat mounting pictures
I can' believe no one has been able to help you by now. I will take pics and post for you today!
Pics coming in a minute
I went out and got some quick pics of the floor mounting locations for the back seat and the underneath side. Hope they help, let me know if you need something else!
More pics, this is my 56K mile 1970 Blazer 4WD BTW.
On the under side, the 4 holes in a row are the bar support you see and the 2 holes to the front of them are backed by the little plate and caged nut setup. I hope this is clear to you because I can see where it may be a tad confusing.
That helps a lot. I got the reinforcing bar , but don't believe I got the front ones. I also don't have those plates on the top side of the bed. Looks like I will have to find some of those or make them.
Thanks again.
New Member
I was needing the same info. Does anybody have a measurement how far the holes are located from the back edge of the tub?
I will get the measurement in a few and post.
For you drunkbus 30 3/4 inches from the back of the tub to centerline of the back row of 4 bolt holes. Hope that helps.
New Member
![]() Join Date: Nov 2006
Thanks for this info and pics as well. Sorry to intrude, but could someone tell me if there would any problems with drilling holes for the rear seat using these measurments and pics to go by. My Blazer (1970) never came with a rear seat and doesn't have any holes to mount one whatsoever.
#13 |
I may have something like that welded to my oringinal floor, have to go look
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
