Old 08-26-2009, 02:39 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Passenger door lock problems?
I have new latches and new chrome handles on little daisy and every time you close the passenger side door it locks itself? Any ideas on what maybe causing this ?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 08-26-2009, 03:32 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Passenger door lock problems?
You may have a left side door latch relay on the right side. They have a spring that pushes it back after you pull it up to open it from the inside. Disconnect the relay and see if it still does it.
dwcsr is offline   Reply With Quote
Old 08-26-2009, 04:41 PM   #3
FRENCHBLUE72
PROJECT 7DEUCE
You are correct it seems however there is a r stamped into the relay but with out it on there the door opens and closes every time with out locking...
MEMBER #6377
Project "7DEUCE"
