Old 01-12-2003, 12:10 PM   #1
Darrell67
Air compressor.What should I buy?
I want to buy a compressor and a sand blaster to do my own sandblasting on my truck. I was looking at a Eagle compressor with 12.5 cfm at 100 lbs. and a 100us sand blaster. Would the compressor be big enough to keep the sand blaster going? Thanks in advance,your advice and experience is appreciated.
67 c20 lwb stepside,327
70 GMC(parts truck)
69 Olds Cutlass(The new baby)
93 silverado 4x4
99 chrysler intrepid
95 ski doo formula st
86 honda 350 4x4
98 Yamaha outboard 25 hp
The one who dies with the most toys wins!!!
Darrell67 is offline   Reply With Quote
Old 01-12-2003, 12:51 PM   #2
mikep
Used to have a truck
mikep's Avatar
Sandblasters use a LOT of air. If the sandblaster your looking at is a pressure pot blaster you could probably get by with that compressor. If its a siphon type forget it. It wont come even close .
No truck :-(
mikep is offline   Reply With Quote
Old 01-12-2003, 01:19 PM   #3
sakohntr
sakohntr's Avatar
compressor
I have a 80 gallon vertical two stage that wont make enough air for my 110 pound pot blaster. I think i am gonna buy another and manifold them together. I would recommend something over 20 cfm for blasting.
1967 K30 Napco 292/SM420 original paint 30k miles
1968 K60 Napco 396/5spd. dbl frame 52" michelins
1969 K10 SWB GMC 454/4spd 6" 35's posi,hooks
1972 C30 longhorn,BB/AT,A/C,Tilt,Toolbox,lokr
1987 K20 Chevrolet Suburban. 6" lift. 5.7L/TH400 1979 K60 GMC Coleman 4x4, 427/Allison.
sakohntr is offline   Reply With Quote
Old 01-12-2003, 01:53 PM   #4
minibike
minibike's Avatar
I would recommend a twin stage 60 gallon as a minimum. This will run most booths, and the small pressure pots (like Harbor Freight sells). I blast weekly with mine. It is an Ingersoll Rand T30
69 SWB
LT1/4L60E
www.classicplace.com
minibike is offline   Reply With Quote
Old 01-12-2003, 04:31 PM   #5
Mike C
Mike C's Avatar
Here is the link to a similar thread on another board I do. Maybe that'll keep this one shorter...
http://www.hybridz.org/ubb/ultimateb...c;f=8;t=001027
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 01-12-2003, 09:18 PM   #6
O'l Buck
Recovering Truck Driver
O'l Buck's Avatar
Don't buy one of those cheapy $400 coleman single stage 6.5 horsepower 60 gallon vertical compressors, I hate mine. It won't keep up with anyting.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option
00 Dodge 2500 4x4, 24V cummins, 5 speed
Chad
South Central Nebraska
O'l Buck is offline   Reply With Quote
