Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-26-2009, 10:00 PM   #1
GMC70c20
ls wire harness
I just got a 6.0 with the factory wire harness and ecm. I didnt realize how much wire harnesses there is on one of those things. Is there a wire harness made that I could use with the factory ecm that would be just the engine controls and nothing else?
1970 c20 converted to c10 sleeper
1979 c20 the wood hauler
1991 honda civic daily driver
spray and pray baby
GMC70c20 is offline   Reply With Quote
Old 08-27-2009, 03:54 PM   #2
POPO1984
POPO1984's Avatar
Re: ls wire harness
you can send the harness you have to nelson performance in san antonio and they will remove all uneccesary thing. makes it supper clean and easy
1972 SWB Medium Olive
South Houston
Instagram: Antbish84
POPO1984 is offline   Reply With Quote
Old 08-28-2009, 05:11 PM   #3
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
Re: ls wire harness
Jesse at www.wait4meperformance.com can rework your existing harness to a stand alone, remove all the unneeded wiring and connections, and tune the PCM to delete all the unneeded sensors and remove VATS for $360. Just got mine back, about 1 week turnaround. I've used Jesse for several years now for tunes, never a problem. About a dozen wires to connect, everything else is plug-n-play.
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 08-28-2009, 08:58 PM   #4
GMC70c20
Re: ls wire harness
and thats to run the factory injection right?
spray and pray baby
Old 08-28-2009, 09:11 PM   #5
POPO1984
POPO1984's Avatar
Re: ls wire harness
yes factory injection they can also remove o2 sensors for cat deletes and other things just tell them what you want or ask what they suggest. i have used bothe pcm4less and nelson with success
South Houston
Old 08-28-2009, 10:49 PM   #6
glock35ipsc
Re: ls wire harness
The pic I posted is the original harness from the 2006 Silverado donor truck that has been reworked. Things that are not needed for a stand alone swap operation is removed, like the rear O2 sensors, EVAP, EGR (if equipped), etc.
And yes, I am running the original truck injection setup, for now. The engine will go in my 85 just as it came out of the 2006, just prettier!!
Bob
Old 09-19-2009, 02:41 AM   #7
mainermikeyd
mainermikeyd's Avatar
Re: ls wire harness
WOW thats nice!!!!!!!!!!!!!!!!!!!!!!!!
Once a Marine Always a Marine OOH-RAH
GM Fanatic
1982 K20 4" Rancho lift 350cid, edelbrock performer intake 1405 carb, hedman headers, TH350, " Wheres the MUD!!!!!!!!!!"
1986 c30 camper special 454, th400 (for sale)
1984 K10 Big Ten (project) needs motor
1984 C10 355, 700r4, (project) needs shortbox bed
mainermikeyd is offline   Reply With Quote
